Vortech Heads + LT4 hot cam
Old Apr 21, 2003 | 01:31 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Ok, i know there are a lot of people here running the LT4 Hot cam and vortec heads... i bought a GM 350HO crate... and i want to cam it before dump it in the car (daily driver)
Now i know that the stock valve train won't hold up to the .525 lift. and that is the reason they sell the hot cam kit.
but will that slap right on to the vortec heads? or will the heads require some machining?
i'm also pretty sure the dowel pin on the cam needs to be tapped in some.
The only reason i want to go to all this trouble is because i can't find another cam that has a decent vaccum and mileage characteristics.
So to sum up what i am asking is....
from begining to end, (other than gaskets, lubes, and the such)
what all do i need to install the LT4 Hot cam kit, on a Vortec headed- 350HO engine?
Old Apr 21, 2003 | 02:23 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll need to have the guide boss and spring seat machined on the heads.
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
