AND I've turned stupid tonite, how long to erase an Eprom?
Old Apr 25, 2003 | 09:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
as above?
Old Apr 25, 2003 | 10:25 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: AND I've turned stupid tonite, how long to erase an Eprom?
Originally posted by doc
as above?
27 series usually need UV light.
29 series are electrically erasable.
Old Apr 26, 2003 | 01:32 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
is a common "blacklight" sufficient?
How long does it need to be in contact with the light?
Old Apr 26, 2003 | 01:41 AM
funstick's Avatar
no but a germicidal lamp from the pet store will be.
Old Apr 26, 2003 | 08:12 AM
JohnL's Avatar
as above?
The short answer for me is 5 to 7 minutes.
My Ango eraser uses a 4W Germicidal tube. The instructions say the time required to complete an erase cycle will depend on two factors: the intensity of the UV source; the erase energy required as specified by the EPROM manufacturer in Watt-Second per sq.cm. Erase time = (erase energy)/(intensity of UV source).
For my eraser, I find that for one chip, 5 to 7 minutes is enough to get all FF's, but the instructions says the erase time varies as follows (with the chip layout and energy required):
Code:
Erasure time in minutes:
# of chips    6W-S/sq.cm.  10W-S/sq.cm.   15W-S/sq.cm.
1              10              20               30
6              10              20               30
9              15              25               35
John
Old Apr 26, 2003 | 11:01 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thanks,
It is a 27C128 chip. And it was completely erased in 45 minutes.
I think with my UV eraser light Eproms will erase in about 20 minutes which is confirmed in the table above.
Thank you to all who responded.
Old Apr 26, 2003 | 11:05 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Doc, is this a "virgin" eprom or has she been around the block a couple of times?
I always started with 10 minutes and then slowly increased the time as used it.
Before I finally threw all my eproms in the garbage and went Flash Prom (hint), I found that after a couple times erasing at one time, that I would have to slowly start increasing the time if I wanted the eprom to erase properly for a good "reburn".
Early on when I first started to burn eproms, I found that after about 4-6 times of burning (let's say I was using 10 minutes to erase each eprom), that if I didn't increase the erasing time (I used 1 minute increments) that the eprom would appear to be erased properly, appear to burn properly, started the car and ran.
BUT - I would get a weird error code after about 15 - 30 minutes of running the car. Initially I thought it was something weird with either the (then) new version of TunerCat, Xtronics burning software or the eprom.
I had a spare Memcal, with the IDENTICAL BIN on it and it ran GREAT with no error codes.
I then took that eprom and increased the erasing time and VOILA, now the eprom was working great. That is when I started to control and record the erasing time I used for each eprom - trying to increase the erasing time at the slowest rate to get the maximum number of uses out of the eprom until it eventually was taking a LONG time to erase properly and finally wouldn't.
Lastly, the amount of "initial time" also is affected by how close the window in the eprom is to the UV Light. I used to erase the eprom directly on the Memcal, but I found that the slight difference in distance (compared to an eprom not installed in a Memcal) was enough to affect the erasing times.
Old Apr 26, 2003 | 11:39 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
do you need to change anything to switch over to flash PROMS? or is there different hardware you need...
i would love to switch over, do i just need to buy some flash chips?
Old Apr 27, 2003 | 09:42 AM
Car: Death Mobile
Engine: 666 c.i.
King, you just swap the Flash Prom (Atmel AT29C256) in place of the stock 27C256 (or 27C128) - and set the your "burner/programmer" to the AT29C256. That's it.
You may wish to consider Craig Moate's adapter with a Flash Prom or two. It REALLY saves the socket on your ECM over the long hall. Better to bend a pin or two on a Flash Prom which is only a few bucks rather than damage your ECM from continous removal/reinstallation of the Memcal.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
Warlocksirix
Sep 3, 2015 12:26 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
