Is Ceramic Coating Necessary?
Old May 23, 2003 | 09:40 AM
brooklyn's Avatar
I was recently talking to someone about headers, and the issue of coating came up. The person said that uncoated headers were responsible for the MELTING/BURNING of some of the sensors around the engine block, including the starter.
Is this really a problem? Is the heat generated by the pipes able to melt sensors?
Another quick question; recommended CAT-BACK for Heddman headers #68470
Old May 23, 2003 | 09:53 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
No, it's not necessary. It is a great help from what I hear.
Though without coating, you can't have anything laying on the headers as it will burn. Coating also keeps underhood temps lower and protects against rusting.
Old May 23, 2003 | 09:55 AM
eric m 91 rs's Avatar
its not necessary
but i would recomend it, and yes those headers get plenty hot to melt away sensors, wires or whatever else happens to be too close to the headers. the coating can only help, it will knock down your engine bay temps considerably and not only that it makes the headers and the engine bay look alot cleaner in my opinion.
Old May 23, 2003 | 11:25 AM
MdFormula350's Avatar
like they said not necessary but i opted to get my slp headers coated so they look good for awhile and keep engine bay temps down.
Old May 23, 2003 | 01:15 PM
rezinn's Avatar
Coating offers a few benefits that I've read of and experienced:
Lower underhood temperatures, which means yes you can have things closer to them. Still, you won't be laying wires on your headers.
Longer lasting, no rusty headers needing to be replaced.
Improved performance.
Old May 24, 2003 | 08:12 AM
Dr G's Avatar
In short:-
Necessary:- Not at all.
Desirable:- Absolutely.
Advantages:-
1. Better exhaust gas velocity, due to the increased temperature of the gases as less radiant heat is produced.
2. Aesthetically nicer than stock manifolds or rusty headers.
3. Lower ambient underhood temperatures.
Disadvantages:-
1. Cost.
2. ? Durability of some companies coatings in the long-term.
Also, any headers may possibly cause trouble with the starter motor - just ensure you have adequate clearance to allow airflow for cooling. With some headers the best long term idea is to fit a Mini-Starter.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
