Did some polishing today :D
Old May 23, 2003 | 09:48 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I finally had the chance to polish my parts back up today 10 months of neglect and dirt roads left my plenum, and well the entire engine compartment filthy.
Before
Attached Thumbnails Did some polishing today :D-before.jpg
Old May 23, 2003 | 09:50 PM
Car: 85 Camaro SC
Engine: V6
Before #2
Attached Thumbnails Did some polishing today :D-before1.jpg
Old May 23, 2003 | 09:52 PM
Car: 85 Camaro SC
Engine: V6
After a few hours of fun
Attached Thumbnails Did some polishing today :D-after-all1.jpg
Old May 23, 2003 | 09:54 PM
Car: 85 Camaro SC
Engine: V6
Side view, yes I even polished the IAC valve body :sillylol:
Attached Thumbnails Did some polishing today :D-side-after-all.jpg
Old May 23, 2003 | 09:55 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
Awwww cute wittle v6..........
................. Just kidding!!
That looks crazy good!! That is a extremely good polishing job!!
Old May 23, 2003 | 09:56 PM
Car: 85 Camaro SC
Engine: V6
Close up of the throttle body gun/with AIC
Attached Thumbnails Did some polishing today :D-throttle-body-gun.jpg
Old May 23, 2003 | 09:59 PM
Car: 85 Camaro SC
Engine: V6
Heres the EGR tube and intake air to valve cleaner tube "whatever its called"
Attached Thumbnails Did some polishing today :D-egrtubeairtube.jpg
Old May 23, 2003 | 10:03 PM
Car: 85 Camaro SC
Engine: V6
My 85 Camaro emblem, gotta love custom thing
Attached Thumbnails Did some polishing today :D-85camaro-emblem.jpg
Old May 23, 2003 | 10:05 PM
dsaint1347's Avatar
You are my idol!
How did you do that and can it be done without taking apart the pieces?
Old May 23, 2003 | 10:06 PM
Car: 85 Camaro SC
Engine: V6
Well I guess I can put a V8 part on here too...This is WishmastersIROC Throttle body and gun, and thats not the completely finished version of it yet. TorchRays waterneck is in the top of the pic too.
Attached Thumbnails Did some polishing today :D-johns-parts.jpg
Old May 23, 2003 | 10:12 PM
Car: 85 Camaro SC
Engine: V6
Re: You are my idol!
With a diegrinder, and a bench grinder with polishing wheels, and over a years experiance in polihsing. It would be imposible with the parts all on the car, unless you used a high powered drill but that would make a huge mess in the engine compartment.
Old May 23, 2003 | 10:18 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Nice work man.
That looks hot!
-Schultzy
Old May 23, 2003 | 11:01 PM
MdFormula350's Avatar
:hail: :hail: wow!
Old May 23, 2003 | 11:42 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Now you know next semester I'm going to be knocking down your door with a TPI assembly right? Just making sure you remember
Old May 23, 2003 | 11:55 PM
Car: 85 Camaro SC
Engine: V6
Yep I still remember Whatcha takin at Fayetteville? I don't think I will be at the APA shows this summer
Old May 24, 2003 | 12:18 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Looking good mike.
I've been planning to powdercoat a v6 intake. Of course, a coating can never shine like that.
You gotta teach me how to reach the small spots, I'm doing a set of valve covers for a friends dad, and the part around the bolt mounting holes and where the valve cover actually presses now, I can't get the wheel into. The 1/4" buffing felt bobs suck for me.
Any advice?
Old May 24, 2003 | 12:25 AM
BORLAZ06's Avatar
Wowsers. what a difference. nice work.
Old May 24, 2003 | 06:57 AM
Tyler-88's Avatar
no doubt, that is sexy. im doing my iac and throttle body and ive never polished before. ive spent about 8 hours on it so far and im still not done with my 180grit. i cant even get the corners never mind the deep spaces. i got a dremel and have tried most accesories but nothign seems to work, how did you clean yours up?
Old May 24, 2003 | 11:11 AM
Car: 1987 GTA
Transmission: 4L60e
Taking Comp. Engineering courses As far as the car and shows go...thats up in the air for me right now too. But I'm pretty sure their main show is in September.
Old May 24, 2003 | 12:11 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
wow, that looks great! wanna do my v6 next? and my remaining two rims?
Old May 24, 2003 | 01:25 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
That is insane.
What are you using to sand with? Are you using low grit compounds?
Old May 24, 2003 | 01:31 PM
Car: 85 Camaro SC
Engine: V6
Your polishing by hand? Good luck doin a TB and Gun, it will probally be near impossible to do. I'm not to sure since I have never tried to polish by hand. I only use the expensive polishing equiptment, things can be done to a higher quality and wwaaaaaayyyyyy faster. I used 180,and 320 grits before polishing. Took me a little under 2 hrs with most of the nessicary equiptment to get all that done.
Freeze I'd love to do your stuff but shipping from/to Austria gotta be killer
Thanks for the compliments guys
Old May 24, 2003 | 02:24 PM
Tyler-88's Avatar
dont be shy, tell us what you use
not just "expensive tools"
also, what addons/acessories for these tools?
Old May 24, 2003 | 02:41 PM
Car: 85 Camaro SC
Engine: V6
I cant really tell all my Polishinginc secrets but heres what I basically use:
Polishing wheels
Polishing compounds
Sanding rolls/drums: 180,320 grit straight and taper rolls
DA Paper: 180,320 6' disks
Agh its all so expensive but worth it :O
Old May 24, 2003 | 09:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
bery bery nice.
Old May 24, 2003 | 09:16 PM
Car: 85 Camaro SC
Engine: V6
Did some more
Attached Thumbnails Did some polishing today :D-alt-n-stuf.jpg
Old May 24, 2003 | 09:17 PM
Car: 85 Camaro SC
Engine: V6
finished
Attached Thumbnails Did some polishing today :D-finished-alt-n-stuff.jpg
Old May 24, 2003 | 09:21 PM
Car: 85 Camaro SC
Engine: V6
Ok now with everything bolted in,
Attached Thumbnails Did some polishing today :D-engine.jpg
Old May 24, 2003 | 09:22 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Old May 24, 2003 | 09:23 PM
Car: 85 Camaro SC
Engine: V6
Attached Thumbnails Did some polishing today :D-engine2.jpg
Old May 24, 2003 | 09:27 PM
Car: 85 Camaro SC
Engine: V6
#3, I even have stock chrome valve covers
Attached Thumbnails Did some polishing today :D-engine3.jpg
Old May 24, 2003 | 09:28 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
u sure u didnt dip that in chrome? that looks amazing.
Old May 24, 2003 | 09:29 PM
Car: 85 Camaro SC
Engine: V6
Last one for fun DA Hogs, now if I only had a trailer hitch to put this on
Attached Thumbnails Did some polishing today :D-dahog.jpg
Old May 24, 2003 | 09:31 PM
Car: 85 Camaro SC
Engine: V6
Nope not chrome diped, I havent bought the 3grand chroming kit I wanna get.
You should do your AC condensor and lines.
Old May 24, 2003 | 09:40 PM
Car: 85 Camaro SC
Engine: V6
I would but I would have to remove everything and do my magic to it. I may in the future but not right now. Did a tune up to the motor too, purrs like a kitten and grunts like a hog because of the pass side exhaust leak Soon to be fixed when my newer exhaust manifold comes in.
Old May 24, 2003 | 09:41 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Nice job. I cant believe you didnt clean up that filthy pulley on the alternator though.
Old May 24, 2003 | 10:09 PM
Car: 85 Camaro SC
Engine: V6
Tommorow I'm going to de grease the engine, and paint the pulleys and the driver fender, its still white and not black.
Old May 24, 2003 | 10:22 PM
Car: 1987 GTA
Transmission: 4L60e
:hail: Da Hogs! haha. Nice piece there man
Old May 24, 2003 | 11:49 PM
25THRSS's Avatar
Looks great man. Awesome polishing job. Makes that V6 looks real good.
Old May 25, 2003 | 12:49 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
wow very nice!
Old May 25, 2003 | 02:44 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
WOW, looks good man. How in the world do you get everything so smooth with sanding rolls/drums? Every time I use them on a corner or curve, I end up messing up the curves and flatting off the edges.
Have you ever tried sanding compound that you add to your buffing wheel? Like this from Eastwood Company: Item No. - 13132
Old May 25, 2003 | 03:34 PM
Car: 85 Camaro SC
Engine: V6
I can sand pretty smooth in the tight areas as long as the dia of the sanding rolls are smaller than the area that I'm working on. Years practice helped out a bunch.
Yeah I use the compounds but they come in a bar form. Both ways use the same concept, grits in the compound to help polish better.
Old May 25, 2003 | 07:13 PM
A88GTANotchback's Avatar
that looks awesome man. 100% better
Old May 25, 2003 | 07:28 PM
lock's Avatar
Car: 86 IROC-Z
That will make it nice
Old May 27, 2003 | 10:17 PM
Car: 85 Camaro SC
Engine: V6
Did something for you v8 guys. I couldnt polish the lines on top cause I don't have the proper wheel to polish in inbetween those lines. Got the lil V6 all finished up sunday too
Attached Thumbnails Did some polishing today :D-plenum2.jpg
Old May 28, 2003 | 01:30 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
all u need to do is port that plenum
what polish do u use?
Old May 28, 2003 | 10:32 AM
'86-5.7L-IROC's Avatar
Car: 86 IROC Z28
Transmission: 700R4 Auto With Shift Kit
Nice but y a V6....They r so slow.....My freinnd has a '96 RS 3.8L and he got beat by a '96 Nissan P/U wit airbags......It takes soo much money to make a V6 as fast as a 350
Old May 28, 2003 | 10:55 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Absolutely amazing work! I need to learn how to do some of that to my engine bay. Great looking stuff. The before and afters just floored me.
You do good work. How much do you charge for polishing?
Old May 28, 2003 | 04:51 PM
Car: 85 Camaro SC
Engine: V6
billsfirebird, heres a link to my pricing page http://www.polishinginc.com./pricing.html
'86-5.7L-IROC, thats the motor she came with. Once I build my 82 Targa Z28 with a LT4 the SC will go in the shop for a facelift and get a LT4 powerplant All polished or Chromed{if I make enough money to buy chroming equiptment} engines of course.
Even thou she's a 6 polished parts make a Big difference.
SLP IROC-Z, I used black emery compound and white rouge compounds.
