Corvette intake set up TPI help
Old May 29, 2003 | 11:24 PM
L98Vette's Avatar
sups guys. I got a 89 L98 TPI vette. I just switched over to a 730 ECM, LT1 intake manifold swap....bolt ons, headers...etc.
one problem I'm havin is the intake piping. what kind of intake is on the 90-92 MAP F body TPI's?? I can't run a 3" pipe over the radiator.. b/c the hood won't close.... I'm trying to pipe 3" pipe into the licesnce plate area...where the KN is that i placed in the nose... but hood clearance is tricky here.. any ideas from you 90-92 F TPI guys??? PIcs?? ideas?? please... thanks.
-Jason
89 L98 Corvette, 730ECM, LT1 intake manifold, headers etc.
Old May 30, 2003 | 12:04 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
How about oval piping maybe?
The 90-92 TPI F bodies just use a longer throttle body boot to make up for lack of the MAF...otherwise the air cleaner assembly is the same for all TPI F bodies.
Old May 31, 2003 | 08:09 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Have you seen these pictures of a LT1 intake conversion in a Corvette?
https://www.thirdgen.org/techbb2/sho...hreadid=182076
Old May 31, 2003 | 09:01 PM
L98Vette's Avatar
Yes.... I'm almost done with my LT1 intake manifold conversion. my question pertained to the actual INTAKE....AIR intake. My problem is i don't want to run the stock air box on my vette. I also don't need the MAF b/c i'm SD.
Old Jun 1, 2003 | 03:04 AM
Z_Ghost's Avatar
Here is a pic for you, hope it helps.
Old Jun 1, 2003 | 12:47 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Axle/Gears: 7.625 10 bolt/3.73s
Wow, there isn't much room to work with. I would prob just clamp a K&N directly to the TB.
Old Jun 1, 2003 | 09:08 PM
Engine: 4.0L
He can't. The LT1 intake conversion on a SBC has the TB sitting very low and farther forward then TPI. A TB air filter would touch the serpentine belt.
Old Jun 1, 2003 | 09:16 PM
Z_Ghost's Avatar
Here is a lt1 in a thirdgen, it has the MAF on it though.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Fast355
Dec 2, 2016 06:33 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
