Exhaust Manifold Gaskets
Old Jun 12, 2003 | 12:54 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Is my car supposed to have these? cause when we took off the manifolds from the 87 2.8 there were no gaskets there, so do i need to put some in before i put it back together?
Old Jun 12, 2003 | 01:21 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
you do not need them. But it IS better to have them.
Old Jun 12, 2003 | 01:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, not quite. The gaskets can blow out and leak. Just stick with the metal-to-metal way that GM used. If you were installing headers, you'd need gaskets.
Old Jun 13, 2003 | 12:25 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
When I took my exhaust manifold off to replace the broken bolts (the genius who rebuilt the thing couldn't be bothered) I decided to put a gasket on. I got this strange Fel-Pro gasket that's composite on one side and metal on the other. I don't think it worked very well. I think it may have even started an exhaust leak. I don't even know which way the gasket is supposed to go.
And btw, it's really hard to drill out a bolt that's sheared off at the block.
1992 Trans Am
May 10, 2023 07:19 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
