80s cluster to 90s cluster
Old Jun 17, 2003 | 11:10 PM
tpi_roc's Avatar
Has anybody swapped from an 80s model cable cluster to a 90s model gauge cluster (electronic VSS) in a camaro?
I'm not so much worried about the wiring of the speedometer as the rest of the cluster/gauges and the mounting
thanks
Old Jun 18, 2003 | 08:03 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Here Ya go I just did that......
Good luck!
https://www.thirdgen.org/techbb2/sho...hreadid=181759
Here is the link to the wiring: http://www.camaro.dnsalias.com:8008/...%20Wiring.html
Old Jun 18, 2003 | 08:18 AM
Car: 85 Z
Engine: 383
Pick of the VSS Buffer box you will need.....
Old Jun 18, 2003 | 09:58 AM
tpi_roc's Avatar
Thanks for the info looks like its everything I need
except
Was there any problems mounting the cluster?
Old Jun 19, 2003 | 09:28 AM
Car: 85 Z
Engine: 383
Yes there is some stuff you will have to cut here is a link that I went to to learn what needed to be done it is just pick but you will know what you need to do from them.....Anything else you need just let me know!
Good Luck!
http://www.camaro.dnsalias.com:8008/84SC/
Old Jun 19, 2003 | 06:35 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
tpi roc,
Do you have a tpi setup and ECM in your car? If you do you probably dont need the VSS Buffer box because the ECM already has it built in to it.
TBI, Carbed Cars need the VSS Buffer, However it all depends on what year.
Old Nov 7, 2003 | 11:59 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I just got a speedo buffer from thirdgenparts.com but it doesn't really match this pic. First the box is white, second some of the wires are different colors, and third I have one less wire. I know the part numbers for all these boxes are the same but it looks like the plugs may not be. I don't kow crap about wiring so please make sure im doing this right.
But the wiring I have from the top of pic down is
connector1
Yellow
Purple
connector 2
pink/black-H
brown-F
red-E
brown-C
black/white-A
On connector2 the wires are lettered A-H. Its hard to tell exactly from the pic above if the wires are in the same slots as mine. SO to be sure Im using the right wires can someone tell me the function of the letters that are used on mine? A-C-E-F-H ThanX
Old Jan 2, 2011 | 03:56 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
Re: 80s cluster to 90s cluster
87 firebird have a buffer box? that I should probably be checking out in my mission to figure out why my speedo does its own thing, wiring diagram shows one so I am guessing so. Just no clue what im looking for as far as buffer box goes.
http://www.youtube.com/watch?v=RTHYtr8YVrE would this black box be my biffer box, passenger side knee high behind glove thing.
(it did, and was yellow box under passengers side dash picky backed on the ecm, like ur pictures above
Bubbajones_ya
Jul 6, 2024 08:32 PM
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
