400 steam holes
Old Jul 18, 2003 | 08:54 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
400 steam holes
hello- i just bought some used dart heads. the guy had them on a 400 in a nova and they look new so they're mine now.when i got home i started going over them again and discovered 3 of the steam holes don't go all the way thru. i try and can't get them with a drill so itake them to a machinist and he tells me there are broken drill bit pieces in there!he says that they regularly get plugged and they aren't that important. how would you feel about running these? i would have at least 1 hole open on each cylinder.
Old Jul 18, 2003 | 09:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would go ahead and drill them. They don't have to be perfectly perpendicular to the head, so just drill them at an angle; feel inside there, and find where the water jacket is, and aim for it. It's not rocket science.
Here's a set of Dart heads that I drilled steam holes in. The ones that are circled are actually at about a 45° angle toward the exhaust port side of the casting. In these particular heads if you try to drill the ones on the intake side straight into the block, you'll never hit water at all, you'll be inside the head bolt boss. That's probably what happened to your heads.... Stimpy left his mark.
Old Jul 18, 2003 | 09:17 PM
craig's Avatar
Car: 86 camaro
i can stick a wire thru the steem holes and see it in the water jacket. what i'm worried about is that on 3 cylinders i'll only have 1 steam hole. the machinist tells me they regularly get plugged with junk in the water any how. do you think they'll run hot?
Old Jul 18, 2003 | 09:50 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Axle/Gears: 3.70
I wouldn't put them on there being plugged. Fix it right and have the peace of mind. Don't trust the machinist.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
drumstixer
Sep 29, 2015 03:02 PM
