Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How should I do...
Old Aug 9, 2003 | 11:58 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
How should I do...
against my buddy's 1988 IROC? He has a 350 TPI auto with an aluminum driveshaft, 2:77 posi, 3in Flowmaster catback, no cat, cut air boxes with K&Ns, and TB bypass. My car is listed in my sig. I know I should beat him but I want to know how close it's going to be. What should I be able to go after with my car?
Old Aug 10, 2003 | 02:34 AM
AndrewJB's Avatar
Car: Crown Vic PI
Your setup sounds pretty similar to mine. You should have no problem walking this guy if you can get the holeshot...your cam and heads will give you an edge in the mid to upper end. Have you taken it to the track? Id say youd probly be able to get mid to high 13's but I suspect those gears are slowin you down just a little
Old Aug 10, 2003 | 03:31 AM
Dan88IrocZ's Avatar
Those gears aren't slowing you down alittle. They are slowing you down a lifetime!!! 3:73's pal!!
camaro922k3
Apr 17, 2004 10:02 AM
F-Body Tim
Apr 8, 2004 11:16 PM
F-Body Tim
Mar 20, 2004 06:45 PM
benoit454
Jan 28, 2004 06:05 PM
BluByU
DIY PROM
Jan 15, 2004 10:36 AM
