Some pictures of my weekend project.
Old Aug 14, 2003 | 07:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i thought i would share some pics of my weekends project.
basicly
Man, not much spare room under the 15" wheels!
Freshly rebuild front end... now my car doesn't wander
The HMS Mounts, finaly installed (yes it is really that dirty under my hood
Here is the brakes, and struts installed!
Old Aug 14, 2003 | 09:59 AM
ebmiller88's Avatar
I know what that is....congrats!!!
:rockon:
Ed
Old Aug 14, 2003 | 11:17 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
How hard is it to rebuild the front end? My car wonders around some...Im thinking about getting all the front steering components from work and rebuilding it. Im torn between doing that or getting a posi rearend first. I need traction bad...
Old Aug 14, 2003 | 11:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
it isn't 'hard' but you do need to have acess to a press. the ball joints, and a-arm bushings need to be pressed in and out. you also need a pickle fork, for seperating the parts, and a spring compressor.
Old Aug 14, 2003 | 01:14 PM
MdFormula350's Avatar
nice job.
Old Aug 14, 2003 | 01:33 PM
ebmiller88's Avatar
Front end rebuild:
http://f1.pg.photos.yahoo.com/ph/tar...tos.yahoo.com/
Ed
Old Aug 14, 2003 | 11:34 PM
Nate's 88's Avatar
i bought a spring compressor when i did my front end, didnt end up using it though. found after getting into it both front springs were broken and didnt find a need for it to put new ones in
what sway bars did you go with on yours?
Old Aug 20, 2003 | 11:20 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
Dewey316
How about some info on those HMS mounts? Never seen those before, would like to know how they are better over stock, aside from the obvious appearance improvement. Where do you get them, and whats the cost?
Old Aug 20, 2003 | 11:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
do a search, it has been covered many many times, he did a limited run of 20 sets, we all paid over $300 when it was said and done. there are a couple other people making them now, and Karl Hunter of HMS, said he would do another run of 20 if there was interest. just do a seach for 'strut mount' or 'HMS mount' you will get a ton of info.
Old Aug 20, 2003 | 09:24 PM
laiky's Avatar
are those c4 front brakes?
Old Aug 20, 2003 | 09:29 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Yes Sir.
Old Aug 21, 2003 | 06:10 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
Dewey316, thanks for taking the time to post the info. After I posted the question, it occurred to me that I should have done the search first. Did the search, found the info. Sorry 'bout that.
Old Aug 21, 2003 | 02:40 PM
laiky's Avatar
hey Dewey, are you the guy who just finished the C4 upgrade. Is that the same one that was discussed on the LS1/C5 posts? I am still very confused about what brakes will work with what wheels. Are the C4's the only ones that will work with factory 15's ?
Old Aug 21, 2003 | 08:20 PM
ebmiller88's Avatar
laiky,
I just did mine also. As far as we know, the C4s are the ONLY brake upgrade being tried out that will fit under those 15" wheels pictured. I have the factory 16s so it wasn't a problem on my end.
Ed
Old Aug 21, 2003 | 09:35 PM
laiky's Avatar
unfortunately my snow tires are on 15 inch z28 rims. Im about to buy a set of KDWS's for my 16's. if they work well enough in the snow i might be able to ditch the snows and just use the KDWS's Will the LS1 brakes fit the 16's. I know this has been covered but my short term memory sucks and the brake posts read like war and peace. I also remember reading ( i think it was you EB) that the C4 setup doesn't offer anymore piston area than the stock single piston setup? How do yours perform? Are they much better than stock?
Old Aug 21, 2003 | 09:45 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
looks good! i love that color blue,what color is it exactly?
Old Aug 22, 2003 | 05:43 AM
Dewey316's Avatar
Car: 1990 Camaro RS
its the factory paint. the exterior of my car is untouched exept for grid style tail lights, clear sidemarkers, and a 91-92 Z grill.
Old Aug 22, 2003 | 06:35 AM
ebmiller88's Avatar
Right..the dual piston calipers have a bit less piston area which give you a harder pedal feel but the performance is better. Alloy can explain all that piston physics stuff better than I can.
They work great! I'm glad I did it. See my ad in the classifieds...
Ed
Old Aug 22, 2003 | 06:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes , the piston size is smaller, so it requires more pedal pressure ot get the same clamping force.
but the swept area is much larger, along with the leverage point, so the actualy stopping power is increased. the other BIG thing this swap helps, is the cooling, with these brakes the large rotors, ect disapate heat much better, we had a rather long auto-x course last weekend (close to 80sec) and i had NO brake fade at all during any of my runs.
Frozer!!!
Jan 19, 2024 04:55 PM
ydnar417
Sep 23, 2015 05:57 AM
kymmee
Sep 2, 2015 09:01 PM
chubsworth
Aug 26, 2015 02:34 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
