LG4 CC Q-jet idle problem
Old Aug 20, 2003 | 09:16 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I have an 82 Trans Am with an open element. I've got a problem with the idle. When the car is warm(190), I turn the motor off, then turn it back on again in 10 minutes. Before I shut it off the idle is at 1,100. When I turn the car back on the idle is at 500.
If I lower the idle it will be impossible to keep the car running after startup.
What do I do?
Old Aug 20, 2003 | 11:03 PM
justinhebert's Avatar
It sounds like your choke is sticking. After your car has warmed up take off the air cleaner and see if your choke blade is fully open or starting to close a little. It sounds like its closing a bit and may need adjustment.
Old Aug 20, 2003 | 11:07 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I've been told either choke or throttle blades. I'm gonna spray the carb with carb cleaner tomorrow morning. I would do it now but you says do not use when engine is hot.
Old Aug 21, 2003 | 09:40 AM
flyway190's Avatar
Are you starting it cold and then letting it warm up and shutting it off or is this after driving?
Old Aug 21, 2003 | 05:47 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
This is after driving for an hour and the motor is warm.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
