ZZ4 recomendations
Old Aug 21, 2003 | 04:53 PM
MizfitCreations's Avatar
Car: 87 Camaro LT
Engine: ZZ4, AFR195, XR276-HR
Transmission: 700R4, Transgo
ZZ4 recomendations
What size carb do you reccomend for an 700R4 with 3.73's
Old Aug 21, 2003 | 04:54 PM
Car: 87 Camaro LT
I also have a CC305 cam and AFR190 heads
Old Aug 21, 2003 | 05:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What torque converter?
Which carb type you should get depends a lot upon intended usage. For the street, a vacuum secondary is pretty forgiving. If you race it regularly, you should consider a mechanical secondary double pumper.
If you follow Holley's recommendations, you don't need any more than a 650 (see this post and the link within https://www.thirdgen.org/techbb2/sho...hreadid=192658 ). If you only have a stock torque converter, 750 is stretching it for a double pumper (check out this post https://www.thirdgen.org/techbb2/sho...hreadid=192317 and the link within for sizing a DP).
This is all assuming you go with a Holley. The same principles apply to a Demon. If you're thinking Edelbrock Performer, I'll decline recommendations because I've never had one and haven't seen a convincing arguement as to why anyone should buy one.
Old Aug 21, 2003 | 05:24 PM
five7kid's Avatar
Oops, read my own link only to discover the link is missing.
Here's the missing link for carb sizing:
http://www.holley.com/HiOctn/ProdLin...FMSC/FMSC.html
Old Aug 21, 2003 | 06:03 PM
Car: 87 Camaro LT
OK, thanx.
I currently have a Street Avenger 770, can I make this work if I do some reworking on it?
Old Aug 21, 2003 | 06:49 PM
five7kid's Avatar
It's a vacuum secondary type. Shouldn't take any reworking, just tuning. Jetting the secondaries is difficult on that particular type, but the way it comes is typically close.
Adjust the idle, jet the primaries, adjust the secondary spring to get rid of bog, it'll be fine.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
