bad motor mount pic
Old Sep 13, 2003 | 01:01 AM
iroctpis's Avatar
bad motor mount pic
I decided to replace my motor mounts after a lot of research. My 89 iroc has had a noticible vibration around 2500rpm, even in park. So here is a pic of a bad motor mount, my car has 100k miles so, I'll test it tommorrow when I finish the other side. The metal was touching metal, the rubber had deteriorated badly over the years. Man what a difference just look at the pics, I went with the stock replacements since the rest of my suspension is real ruff, I didn't want to have a harsher ride.
Old Sep 13, 2003 | 01:37 AM
iroctpis's Avatar
test pic
Old Sep 13, 2003 | 01:49 AM
iroctpis's Avatar
more pics
Here are some more pics of the process. Its time consuming and you just need to remember to have these tools: 3/8" drive with 2 10" extensions, 15mm socket, u-joint socket attachment, permatex, coat hanger, jacks of course, I used a piece of wood to jack the motor up by the dampener. The permatex keeps the bolt/nut in the socket while you put everything back together. The coat hanger is for retrieving nuts/bolts from the crossmember when you drop them. Just remember you can leave the control arm and everything on to get to these bolts, you just have to position and angle through holes and inbetween the coils of the spring.
Old Sep 13, 2003 | 01:51 AM
iroctpis's Avatar
pic
delete
Old Sep 13, 2003 | 12:27 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
All I have to say is wow.
Old Sep 13, 2003 | 02:59 PM
iroctpis's Avatar
pic after
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
