383 shortblock pics
Old Sep 13, 2003 | 10:46 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
383 shortblock pics
Finally got a couple pics of my 383 shortblock
Old Sep 13, 2003 | 10:53 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
sorry, they're so big, I'll see if I can get them smaller
Old Sep 13, 2003 | 10:59 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
another
Old Sep 13, 2003 | 11:07 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
another
Old Sep 13, 2003 | 11:37 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Looks good... Where did you get it from or did you build it yourself? What parts are in it?
Old Sep 14, 2003 | 12:16 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I did want to build it myself but decided to just buy a shortblock from Wheeler Motorsports. As far as the parts that are in it..there's a crank, some pistons, rods, bearings and a cam, lol. But seriously though, it has what they call a "Wheeler Crank" which is an overseas nodular iron crank that is supposed to be rated to 600hp...forged I-beam rods and forged Prode flattop pistons.
Tom
Old Sep 14, 2003 | 12:27 AM
kfoley's Avatar
Car: '85 Z28
Sounds like a stout short block. What's the rest of the buildup going to be (heads, intake, CR, etc.)?
Old Sep 14, 2003 | 12:58 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
The heads are gonna be a set of 200cc Pro Topline with either 10.0 or 10.9:1 compression depending on which cc chamber head I get. The cam is a GM Performance parts cam that has 234/242 duration @.050 and .539/.558 lift (it think they got that grind from Crane cams) And the intake is gonna be a Holley Stealth Ram with 30lbs/hr injectors. I'm hoping to make ~450hp and ~500ft/lbs, what do you guys think?
Tom
Old Sep 14, 2003 | 01:17 AM
kfoley's Avatar
Car: '85 Z28
Sounds like you should be right around 475 hp, maybe a bit more. Those heads flow good and that cam will make lots of power. Should be good for mid - high 11's if you can get traction...
Old Sep 14, 2003 | 09:33 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Well traction is gonna definately be a problem. But I just usually think of the old hotroder's cliche....if your ever gonna have problems with your car..traction is the best one to have. I have absolutlely no rear suspension mods as of right now and don't have plans for any in the near future since I have about $8000 in the motor and new T56 setup that's going in with the new motor. But one thing that I do plan on doing right after I get the motor and trans in is to switch the rear end setup from the current 2.73 open to a 3.73 or 4.10 posi. Other then that, I'll probably been done for awhile.
Tom
Old Sep 14, 2003 | 01:14 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
Is that the Sportsman for $1899.95? keep in touch I am thinking of getting that one. Let me know how she runs.Tim. looks sweet
Old Sep 14, 2003 | 03:10 PM
kfoley's Avatar
Car: '85 Z28
With that 2.73 open rear you wouldn't have any traction, at least with the 3.73/4.10's and a posi you'll be able to get moving while spinning the tires. What diff are you going to go with? Eaton, Auburn, Detroit?
Old Sep 14, 2003 | 04:01 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I haven't decided which one I'm gonna go with yet.
Tom
Old Sep 14, 2003 | 04:17 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Wheeler Block
I have seen that short block before.....did you buy it off Ebay?????
I have seen one listed there and if that is the same one you have, and it is reasonably priced, I am thinking about grabbing me one. Definitely tell us how it runs and surely how it holds up to a little abuse! Questions: one or two piece rear seal, and do you know if it is a roller block or not????
Good luck on your buildup!
Lc
Old Sep 14, 2003 | 06:04 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Re: Wheeler Block
Lc
It is a one peice rear main seal. And yes it is a roller block, if you look closely at the first pic posted, you'll noticed the bosses for the lifter guide retainer.
Tom
Old Sep 25, 2003 | 12:36 AM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
Go with the eaton posi unit...its far better than an auburn or zexel torsens that others use. Trust me I just went through that with mine. A close friend of mine who happens to have years of experience and a sound reputation for building quality rearends for everything from 12 second streetcars to 7 second strip cars say thats the ticket if your gonna stick with the stock 10 bolt.
Doobie52
Sep 11, 2015 06:19 PM
Nick McCardle
Sep 10, 2015 08:36 PM
buckshot63
Sep 10, 2015 09:15 AM
