Nice fall day- polished rim pics
Old Oct 13, 2003 | 05:11 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Well It was a perfect fall day here in the buffalo area, couldn't resist taking some pics of my newly polished-painted rims on such a gorgous day!
one:
Old Oct 13, 2003 | 05:14 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
two:
Old Oct 13, 2003 | 05:18 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
three:
Old Oct 13, 2003 | 06:06 PM
onebinky's Avatar
Those are looking good I just did mine too, but mine were the 16" IROC's. How long do you think it took you to polish those?
Matt
Old Oct 13, 2003 | 06:15 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
That's slick. I need to polish my formies.
Old Oct 13, 2003 | 06:51 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Matt
Well matt,
I've got 2 done the other two still have to be done. As you said in your thread, (by the way yours turned out great!), I bet I have 16 hours easy in the two rims. I significantly reduced the amount of time on the second rim by using 150 grit on a d/a sander then 220 then 320 wet - by hand and 400 wet. Probably cut 1.5 - 2 hours out.
In those pics it's a shame the "true shine" does not show up. They look much better in person.
Old Oct 13, 2003 | 07:22 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Did you paint the inner parts darker?
Old Oct 13, 2003 | 07:28 PM
Calderone's Avatar
Car: 87 Vette
check this
https://www.thirdgen.org/techbb2/sho...37#post1517637
Old Oct 13, 2003 | 07:40 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: Did you paint the inner parts darker?
sammy,
Actually you are the one that gave me the idea with your original post!
I painted them a truck-van metal flake black. This way there is more contrast with the polished surface and brake dust will not be as noticable on the non polished surface.
A little trick that worked for me was to polish first then paint after masking area. Remove tape as soon as you are done painting, so it does not pull on the painted area if it begins to set up. Then after about 1 hour with a old sock and some acetone wipe the excess off the polished area. Works great and gives a nice clean line.
Here is the paint that I used:
Old Oct 13, 2003 | 07:48 PM
Calderone's Avatar
Car: 87 Vette
HAHAHA !!!!COOL !
HEY QUOTE :sammy,
AW MAN.,.IT KICKED AZZZ !!!!!!!!
I WILL DO IT SOON !!!
COOL WHEELS YOU HAVE ....POST MORE SHOTS...!!!!
CONGRATS !!!!!!
Old Oct 13, 2003 | 07:51 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: HAHAHA !!!!COOL !
CONGRATS !!!!!!
did you check out my other thread for pics?
www.thirdgen.org/techbb2/showthread.php?s=&threadid=205241
Old Oct 13, 2003 | 07:56 PM
85_ZED28's Avatar
Car: '85 Z28
Looks great, nice looking car you have there!
Old Oct 13, 2003 | 08:58 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Those look awesome, I like the color you chose to accent them with. :hail:
Old Oct 13, 2003 | 09:11 PM
icebird_1981's Avatar
looks geat! normaly i dont like those style firebirds but man your looks nice. i think u should invest in a set of clear side markers
Old Oct 14, 2003 | 01:09 AM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
I got a pic of that spinning action hes talking about. He is right the darker color really does give a cool effect Mine are Painted Dark Grey
Old Oct 14, 2003 | 09:57 AM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I have an Iroc and I opted to use a darker colour on the incerts as well, instead of black I went with a Charcoal grey metallic. I find it gives the rim a more defined look.
Old Oct 14, 2003 | 03:53 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Actually, that was one of my first choices for color, however, two auto stores didn't have the color so I opted for the black, I'm happy with the way the black turned out.
Old Oct 14, 2003 | 07:21 PM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
novass: Awesome Formula! I love that shade of blue. The black wheel accent paint looks good too on those wheels.
I used gunmetal gray on my IROC wheels though...
more pix at http://mwshowgo67.com/red90iroc/toomanypix.htm
Old Oct 14, 2003 | 11:48 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
how well will that paint hold up? duplicolor has a separate line of paint designed for rims called high performance wheel coating. they have silver, graphite, white, and a clear coat http://duplicolor.com/products/wheel.html i'm in the process of painting my rims (same style as yours). i'm too lazy to polish them though. hell i'm too lazy to tape them of so i can finish painting them lol. i painted the face sections with silver then clearcoated, and i'm going to paint the insets graphite and clearcoat them as well. so far, the silver with the clear coat looks pretty damn good for like 15 mins of work.
Old Oct 15, 2003 | 04:22 AM
I have to ask. If your lazy why did you even Attempt at your wheels. I've Never polished and painted 1 wheel in less then 6 hours.
Old Oct 15, 2003 | 11:42 AM
Diabolical's Avatar
Engine: 305HO L69
that's why i didn't even try to polish. i'm just painting them. it's only a temporary solution, the car will eventually get new rims. all i did was a little sanding to prep for paint, then painted, then cleared. so far i've done 2 rims, just gotta paint the insets, the faces look pretty good, might've spent a total of 1/2 hour on the two of them so far. i will probably tape them off this weekend and paint the insets, then i'll post some pics
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
69 Six Pack
Oct 5, 2015 07:51 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kyleb24
Aug 15, 2015 08:24 AM
