700R4 Shifting
Old Nov 2, 2003 | 02:36 AM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
700R4 Shifting
My car shifts out of 1st gear wayyyyy too early. Almost the second I get on the gas from a stop it goes right into 2nd, and bogs the car. In my 69 Cougar, I could just adjust the vacuum module on the tranny and it would shift at redline if I wanted it to. Is there a simple way of doing that with this tranny?
Chris
Old Nov 2, 2003 | 01:00 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
There is a cable (TV cable) on the side of the throttle body that can be adjusted. If it is loose it will shift too early and soft. If it is too tight it will shift later and firmer.
Old Nov 2, 2003 | 03:09 PM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Thanks!! I looked at the TB and sure enough, they all seem loose, but there are three (Im guessing the TV cable, CC, and throttle), which one is the TV cable? And, how do I adjust it?
Thanks!!
Old Nov 2, 2003 | 03:26 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/tech/detent.shtml
Old Nov 2, 2003 | 06:30 PM
joshwilson3's Avatar
Old Nov 3, 2003 | 12:43 PM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Yeah, does anyone know which one is the right cable, and where the little d button is to adjust it?
Thanks!
Chris
Old Nov 5, 2003 | 12:49 AM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Anyone??
Chris
Old Nov 6, 2003 | 08:18 PM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Nobody knows which cable is the right one? Come on guys, please!! You've all adjusted it, so you must know the right one!
Chris
Old Nov 7, 2003 | 09:46 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
The throttle cable is extremely easy to identify so you can eliminate that one by pressing the gas pedal.
The TV cable comes through a black housing with a square button on the side.
Old Nov 8, 2003 | 07:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
We aim to please
RBob.
Old Nov 8, 2003 | 11:38 AM
Old Nov 8, 2003 | 02:17 PM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Thanks guys, adjusted it today, took less than a minute and made one of the biggest differences I've ever seen!!
Old Nov 9, 2003 | 05:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
joshwilson3: the one being installed is the TV cable. The one in place is the throttle cable. The missing one is the cruise control cable.
cmpcpro: sounds good!
RBob.
Old Nov 9, 2003 | 05:48 PM
loud91rs
Oct 5, 2015 10:05 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
