Buffer box Wireing????????
Old Nov 10, 2003 | 08:16 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
If anyone has wiring diagrams for a 3rdgen that used an electric speedo and had a seperate buffer box like the late 80's firebirds and some tbi cars, can you get me the functions of the wires on connector 2 of the buffer box. The wires I have are listed below. I did a search and saw a couple of pics of these boxes and plugs and they had different colored wires or differ # of wires than mine.
connector1
Yellow
Purple
connector 2
A-black/white
C-brown
E-red
F-brown
H-pink/black
On connector2 the wires are lettered A-H. Its hard to tell exactly from the pics I saw when I searched if the wires were in the same slots as mine. SO to be sure Im using the right wires can someone tell me the function of the wires in slots A-C-E-F and H ???
Old Nov 11, 2003 | 04:29 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Hi John...still wrestling with this are you? You are persistant; I hope it works out!
When I installed the box in my Formula, the second connector went on in reverse order to what you have listed for the colors.
A-black/white goes to ground
C-brown (2 wires) sent the signal to the ECM for convertor lockup, cruise, etc.
E-red ?
F-brown ? my next one was green with a black stripe which went to the speedo head
H-pink/black was a switched 12v power source
Below is a slightly brightened version of the original scan of the buffer box.
Pete
Old Nov 13, 2003 | 07:04 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I just looked at the 92 Shop Manual and found the following chart for the V8 engine (Vin Code 'E')
C2
A)Black/White = Ground
C)Tan = Instument Cluster input
E)Red = Cruise Module
F)Brown = ECM input
H)Pink/black = Ignition
Old Nov 14, 2003 | 06:02 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
ThanX guys.
John in RI, I just found out my box was from a '92 so that should work out great.
Hopefully I can get this project started and done soon.
Old Nov 16, 2003 | 02:40 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
What cars can I get a buffer box out of and where are these things located in the cars? Thanks.
Old Nov 16, 2003 | 04:24 PM
On the 86-up Firebirds, they are piggybacked onto the ECM above the passenger footwell.
Pete
Old Nov 16, 2003 | 04:55 PM
John in RI's Avatar
These things wer mounted in all the 84-86 Berlinettas and the 92 TBI cars that I know of.
I know the Firebirds used the electric Speedo sending unit around 87 & up - but don't know what years or engines types used the VSS box.
Pete: I wrote this post before you - but was kicked ofline and posted it after you !
Wierd ---------->
Street Lethal
Apr 30, 2019 12:14 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
marcusaw
Aug 10, 2015 08:13 AM
