New best times...
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
New best times...
Drove my IROC out to Cecil County. 2 hour drive each way. Street trim with swaybars, interior, etc. Bolted on a set of front skinnies. End result...
60' : 1.624
330' : 4.765
1/8 : 7.424
MPH : 91.94
1000' : 9.731
1/4 : 11.665
MPH : 117.20
To say that I was surprised by this ET is an understatement. I had no idea my new combo had this type of power. I literally just got the car together and did some minor street tuning by Cecil and then raced. I would have been satisfied with low 12's (my previous best). I was optimistically praying for 11.8's but REALLY believing that I would not hit 11's. Scary thing is - the car was in street trim except for the front skinnies. I think she's capable of 11.5's in track trim :-O
The car is a 1990 IROC-Z. It's an anamoly. The stock 350 shortblock has NEVER been out of the car. GM must have been having a good day on the assembly line back in 1990. The 700R4 tranny has never been rebuilt. It has the 10-bolt rear to boot. All naturally aspirated. No juice or force. Basically, it’s a MiniRam sitting on top of ported AFR190s with a Lethal EFI Performance Camshaft and long tubes through a single 3" exhaust.
... The mph still blows me away when I think about it in respect to what my car is. FWIW, my first time down the track was a 11.89@115 with me letting off because the tranny didn't shift into 3rd. The next run I got it to shift into third and pulled a better 60ft (preloaded the converter) resulting in my better times.
ABSOLUTE HUGE thanks to, in no particular order: Mike, Dave, Andris, Mark, Greg, Rick, and Kev. Without you guys this never would have happened. From everything from motivation, food, tire pressure, pit crew-ing, to camera work, to girly drinks. Woot! Thanks a bunch.
8.6M Video of the run...
http://www.bescaredracing.com/iroc/movies/track.wmv
Tim
60' : 1.624
330' : 4.765
1/8 : 7.424
MPH : 91.94
1000' : 9.731
1/4 : 11.665
MPH : 117.20
Tim
Car: Death Mobile
Engine: 666 c.i.
Excellent results Tim. Amazing what the "puny" 350 with the stock two bolt bottom-end is capable of putting out and still hang together.
Might want to look at your Governor Valve on the Tranny. I had a similar problem with my tranny where it just didn't want to go into 4th and that was the culprit. It bascially felt as if the TV cable was WAY out of adjustment (but wasn't).
Do I dare ask what you are shifting at?
Originally posted by OMINOUS_87
What was in place to hook the rears?
Tim
Tim
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Nice times Tim.. I wish that I knew that you were going to be down at Cecil today. I would have made the trip down just to see ya run.
Kat
Kat
Kat
Kat
Tim
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Cool! I wanna see the videos, I really like how your car sounds.
Congrats dude....I just knew your car was going to run better than what you expected!! Once I get off my butt and swap my clutch I can head back to the track to see some results of my latest round of mods.
I can't talk about the cam specifics as per an agreement with Joe Overton (Lethal EFI Performance). However, I can say the following ... I was already in the process of picking a new cam and the cam that Joe ground for me is fairly close to the direction I was headed. David Vizard's book on Modifying Chevrolet Camshafts and Valvetrain Components explains the deal on cam figures vs. overall horsepower and torque. Everything that book said - matches exactly how my new LEFI cam worked. However, even if Joe were to tell the specs then that would only be part of the story. Lobe Shape, symmetry, etc. is also very important.
Tim
Tim
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
How can I get ahold of this Overton guy? I mean personally I think keeping a cam grind "secret" is gay gay and just plain gay, unless you're the points leader or close to it in whatever racing league you may be in. I mean your car is just for fun at the track and street use isn't it? I'm not trying to knock you in any way Tim, but I guess I'm just nosey and I want to know why Joe doesn't want to give out the specs? Is it that he doesn't want someone to steal his ideas? Really there's really only so much you can do with camshaft designs and I'm sure Comp could make a grind to equal the abilities of the cam you're running by just using their generic lobe designs. I guess you're wanting to keep the car as streetable as possible while at the same time being as wicked-fast as possible. Please help me understand, why we can't know the cam specs.
Later.
Joe
Later.Joe
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Bad *** video. Tell the guy that you wasted he needs to work on his RT!
Can't wait to see what drag radials and 41psi will do to my 13.7 w/ 28psi fuel pressure.
Cool runs man, and I bet you can improve with more WOT tunage!
Car: '91 Firebird
Engine: 408 SBC
Congratulations!
Very nice times TRAXION. Nice car - I like that you kept the factory hood for the sleeper effect. What kind of tires are you running out back? They must be some type of drag radial to be hooking up that good. Thanks for sharing - that video is awsome!
wingnut,
255 Drag radials on stock 16" IROC rims out back. With the normal front IROC rims/tires installed the car looks totally stock. It doesn't sound stock. But it does look stock - lol.
Tim
Tim
Tim
hehe right on. Just looked like I saw the green a bit longer than I should have before the car moved.
But hey that's all I can be good at is RT since my car is slow!
Tim
Tim
Congratulations on the new ET and mph Tim, especially with the car being in street trim.
Gordon
Originally posted by HybridZ28
Nice run man .. I was there and saw it.. very impressed .. was going to talk at ya.
But was trying to figure out what was going on with my POS
Tim
The black car is a '92 convertible with ...
SuperRam
AFR190s
HOT Cam
406ci SBC
T56
usual mods like headers, gears, etc.
12.0's @ 112mph. With a more stout cam that car will go easy 11's. It's an incredibly torquey car and kicks butt on the road course! I'm trying to talk him into putting a real cam in there. It's losing major HP with that little baby cam. Hi Dave!
Tim
SuperRam
AFR190s
HOT Cam
406ci SBC
T56
Tim
Car: Faster
Engine: Than
Transmission: You!
YEa I agree about the cam. My cam is even bigger than the HOT cam and I thought I was being conservative when I chose the XR276HR-12 for my little 355 !
The specs of the Comp 306 might be a good choice for his motor.
Oh, and what gears is he running?
Tim
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Trax,
So, you had a custom Comp Cams Cam and then pulled it out without going to the track and put this custom cam in? That seems odd that you wouldn't even test it??! Is your butt dyno that accurate?
Also, without commenting on where the duration occurs or if you have assymetrical lobes or whatever could you get us close to the cam specs? How about within 5 degrees at .050? That can't be giving away any secrets? I assume over 238 degrees.
Things I know:
76 kpa idle (ouch!)
900 rpm idle
I think you said 20d overlap at .050 specs.
Judging by those I would assume that you have a similar cam (in .050 duration only) to the one in my 406.
Also, my 406 has a 1kpa change from going from a 48mm to a 58mm throttle body. I really doubt the need for a monoblade.
Is it actually possible to acheive atmospheric pressure inside the intake at WOT? Can't you only approach it?
Anyhow, impressive times, nice work.
Things I know:
76 kpa idle (ouch!)
900 rpm idle
Tim
Car: 1991 Firebird
Engine: 427 LSX
Ok, wow, all I asked for was total duration within 5 plus or minus degrees. I didn't think that was too specific. Apparently the Dave Vizard Book has some serious hints...........
traction was the problem... made 4 runs .. 1st 12.9, then changed to a diffrent tune 2nd run 13.8 ick lowered tire pressure/changed launch style 3rd run 13.5 and it smoked the tires to about 60 mark , 4th run re flashed to the old tune and bang 12.9.
So I'm back to where I was.
Nothing some suspension mods and new tires wont fix
2.8 60's SUCK!
2.8 60's SUCK!
Ya. I saw your car there. I didn't see you run though. What problems were you having?
Tim
Tim
Tim
Car: 91 Z28
Engine: Forged 383
Alright, man, I'll just hurry up and run out and buy the David Wizard book. lol. Since I never got a reply and others haven't about the cam, I guess the only thing I can do is laugh when thinking about the"secret" cam specs of your cam. Woo hoo. Keeping cam specs unknown sounds somewhat childish, I don't car what the heck the reason is, but you are a Mod, right? I guess the car runs though...
1bad91Z, I've heard about those reverse split cams on the vette forum. 89Vette is running one w/ his SR and AFR's. He's the C4 guy that I know did this and he never posted the results w/ this cam.
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Originally posted by derfrank
Traxion made a agreement with Lethal EFI Joe Overton that he wouldn't give out the cam specs. I'm sure if they didn't agree on it, Traxion would be more than happy to give out the cam specs. Hes giving out hints on where to find the cam specs without himself giving them out.
Don't you think I would like to tell everyone? Of course I would. However, that's not how I operate. Joe specifically requested that I not tell anyone. That was the deal I had to make. So, I told Joe I wouldn't tell. So, I am not. Me thinks that camarojoe is not an honest person if he doesn't understand keeping your word
I'm sorry that you want to trash me because I'm an honest person and I don't lie.Tim
Car: 91 Z28
Engine: Forged 383
Trax, I'm sorry about saying what I did if it made you think I sound dishonest. Honestly I respect you and your knowledge more than 99.999% of the people on this board if that says much. You know 100x's more than me about these cars and I'll admit it. The only reason I said what I did is that I kinda feel after all the stuff you've given these boards, why can't you post the specs or at least talk to Joe again and see if he still cares if you post em. It would make some of us happy to know what parts add up to make your car scream.
This was my thinking on why I wrote what I did. So that's my reasoning. But know after thinking about it, you really don't owe us jack, but if you are able to post the specs at a later date, I'd love to know them. Good luck getting some 11.50's.
Joe
This was my thinking on why I wrote what I did. So that's my reasoning. But know after thinking about it, you really don't owe us jack, but if you are able to post the specs at a later date, I'd love to know them. Good luck getting some 11.50's. Joe
