Finally, got pics of my hooker long tube/dual 3inch x pipe system!
Old Nov 16, 2003 | 03:39 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
took a while to get em online but here they are
Old Nov 16, 2003 | 04:27 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
what kind of ground clearance does that system have?
Old Nov 16, 2003 | 06:43 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
sweet. 3 in? if you know or dont mind finding out, how far does it go straight from the collector, what degree bend? any close ups of the x?
Old Nov 16, 2003 | 07:59 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Nice job looks like you have no clearance issues and you did the duals right with the crossover. You probably got some respectable gains from that whole setup. Any dyno results?
Old Nov 16, 2003 | 09:19 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
With exception to the mufflers showing off just how unsymmetric the rear section of the car is, it looks like a really well made setup.
Old Nov 16, 2003 | 11:23 PM
Car: Junk
Yeah, I know, there was no way around that because of the stupid spare tire hump, which we bashed in a little. Ground clearance is OK, would be perfect if the car wasn't lowered 2 nches.
Old Nov 17, 2003 | 03:12 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Now its time for a new tranny Chris, before you kill that T5.
Old Nov 17, 2003 | 09:34 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
umm newb question, why run an X pipe instead of true duals the whole way back??
Old Nov 17, 2003 | 02:48 PM
Car: Junk
X pipe is to synchronise and equally scavage the left and right cylinder banks when you run a dual exhaust, a problem that is non-existent if you have a single 3inch setup. Its better than an H pipe because the exhaust travels through curves instead of straight angles (X H see!)
Old Nov 17, 2003 | 07:46 PM
MdFormula350's Avatar
nice looking, must flow very well.
Old Nov 21, 2003 | 08:26 PM
fast86z's Avatar
Car: 1984 Pontiac Trans Am
i bet the system sounds sweet
Old Feb 6, 2004 | 10:03 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Any side pics of the car? I would like to see ground clearance of the new pipes.
It's looks killer though!!! Nice job!
Old Feb 7, 2004 | 10:26 AM
destroyer1's Avatar
Set-up looks awesome!!! Did you have to remove the stupid piece of metal that connects the rear to the tranny or do firebirds not have them like my Camaro does? Either way :hail: :hail: :hail:
Old Feb 7, 2004 | 10:38 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
are you talking about the cross member or the driveshaft, cause i think you need both....
Old Feb 8, 2004 | 08:10 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I think he means the torque arm. And unless you have a 4 link or other rear suspension setup, yes you need that too
Old Feb 8, 2004 | 08:34 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
sound files would be cool along with cam specs
Old Feb 10, 2004 | 06:05 PM
CGCBandit's Avatar
Wow
Looks real good man, if you don't mind me asking how much did that cost to have done? Looks top notch :hail:
Old Feb 10, 2004 | 06:29 PM
blue_tacos's Avatar
Car: 82 Berlinetta 87 Iroc
Engine: 327
very nice looking
Old Mar 22, 2004 | 09:00 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
lol i hope to *** your not talking about the torque arm
is that under the axel or over on the exaust?
Old Mar 23, 2004 | 09:03 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
chris, I was looking at the super comps for my track only car,,I was thinking,,,,,,HOK-2210 At www.summitracing.com any help would be great,,,,no exhaust just open headers
Old Mar 23, 2004 | 09:19 AM
MCas7's Avatar
I have a question, what if you have to take your transmission out? How do you get it out with the exhaust in the way? And does the exhaust go under the rear axle?
Riley's
HOK 2210 is a great header for the track, but just the plain 2210 doesn't come coated. I believe the 2210-1 is coated but it's like $200 more.
Old Mar 23, 2004 | 05:22 PM
Kontrax's Avatar
Car: 86 Camaro
if you gotta drop the tranny, the exaust has to come out
Old Mar 23, 2004 | 06:15 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I want side pics, my system is not much different from that and ground clearance sucks.
Edit: Come to look at it, that is better than mine because of that cross member. Get some side pics .
Old Mar 25, 2004 | 05:18 PM
1QWIKZ's Avatar
Car: 88 Camaro
Transmission: TH-350
Looks real good dude! Nice job!
Old Mar 27, 2004 | 11:20 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
that looks almost exactly liek the exhaust system i want. so if didnt lower my car at all from standard ride height, do you guys think i woudl have much clearance problems?
P.S. where does that pipe run when it gets to the rear axle?
Old Mar 27, 2004 | 02:03 PM
Engine: 406
Originally posted by MCas7
Riley's
Got the 2210's only hope to run 11-10 secs at a time,,
Old Mar 31, 2004 | 03:28 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
ChrisFormula355, you still around? Any pictures from the side? That looks like a pretty good setup. later
Old Apr 5, 2004 | 01:32 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
If you have to drop the tranny, then taking the exhaust off doens't look like that much work, since it doesn't go over the rear axle. If it did go over the axle, I'd put some dr. gas ball/cone joints in it so you wouldn't have to drop the axle, too.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
TheExaminer
Aug 26, 2015 04:59 PM
makaveli09
Aug 12, 2015 09:07 PM
