heater hose routing question
Old Dec 4, 2003 | 05:40 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
my car was gutted a long time ago for strip only, but now i am slowly piecing it back together for a little bit of comfort. I installed a non-a/c heater box and everything to go along with it. I can not run the heater hoses the way the factory did due to lack of fitting on the intake manifold. So my idea is to run the larger of the two hoses(3/4") to the water pump and the smaller hose(5/8") to a radiator out of a fuel injected style radiator---remember carb'd cars had no fitting on the radiator--only intake manifold and water pump.
My question is as follows: Will coolant still circulate properly utilizing the water pump as the send and the radiator as the return? was the water pump the send from the factory and the intake the return?
Old Dec 4, 2003 | 06:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Coolant flows out of the intake manifold to the heater core and then back to the suction side of the water pump, or returns back to the radiator in the case of TPI cars.
Old Dec 4, 2003 | 08:22 PM
xpndbl3's Avatar
Car: 1984 Z28
so basically i have two sides that are suction?
Old Dec 4, 2003 | 09:49 PM
breathment's Avatar
ya one small one big. on the waterpump.
Old Dec 5, 2003 | 12:17 AM
xpndbl3's Avatar
Car: 1984 Z28
geez....gonna have to come up with another idea to run some hoses then after all.
Old Dec 9, 2003 | 06:42 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
There has to be SOME coolant port on the intake. It doesn't matter if it's in the same place, or even the same channel really. I've never seen an intake that didn't have a port for a temp sender (except homemade sheetmetal intakes.)
If it comes down to it you can use the port in the side of the head between cylinders 6 and 8 as a feed port, and return to either the pump or the radiator. If you already have a sensor in that port just put a T fitting in it.
Old Dec 9, 2003 | 08:01 PM
xpndbl3's Avatar
Car: 1984 Z28
well actually that temp port is being used by my autometer temp sensor, guess now it'll be bumped up to the water neck and the heat fitting moved back there. thanks for the suggestions.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
redmaroz
Aug 16, 2015 11:40 PM
