Anybody able to fit a 142/177 blower under a 4" cowl?
Old Dec 18, 2003 | 07:43 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Just curious, pics if you have some .
Old Dec 18, 2003 | 08:19 PM
Damon's Avatar
The 142 maybe. The 177 no way. It sits a full 2" higher overall than the 142, partially because it's a bigger blower overall, and partially becuase the lower intake is significantly taller than the one used for the 142.
Old Dec 18, 2003 | 08:42 PM
How much horsepower would the 142 support? Super chevy made 600 horsepower on a 355 with the 177...
Old Dec 19, 2003 | 12:50 AM
Looking at this chart:
http://www.holley.com/HiOctn/TechSer...o/SCTech3.html
It looks like the only real difference in height is the intake manifold on these. Are the intakes on the 142 and 177 interchangable?
Old Dec 19, 2003 | 05:44 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
I have no clue but it looks like they have different part numbers.
WND-6150 Intake Manifold Satin 177 Supercharger Chevy 262-400 1-9 $338.90
WND-6110 Intake Manifold Satin 142 Supercharger Chevy 262-400 1-9 $317.69
383 CID "Enforcer 525" Supercharged Engine, 4 bolt main block, 5140 steel rods, JE blower pistons, Comp Cams hyd. cam. stage I ported Edelbrock alum. cyl. heads, Weiand 142 supercharger, 750 carb, MSD 525 hp $8,995.00
350 with 142 that Chevy High Performance did, Nice article 8 parts full build up
Old Dec 19, 2003 | 05:49 PM
bttt
Old Dec 19, 2003 | 08:28 PM
Damon's Avatar
My expereince is that the little 142 is basically "all done" by 500 HP (I'm making 480HP on a 383ci engine and I'm one step from maxed-out on pulleys). The 177 is gonna be all done around 600.
The lower intakes are definitely NOT interchangable between the two.
Old Dec 24, 2003 | 10:51 PM
89rs/sc's Avatar
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
re:hood
fit under the goodmark cowl hood email me for pics rory@net2music.com
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
