gauge question, stock shiftlight and gauge cluster wire mapping
Old Dec 25, 2003 | 06:58 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
ok, the stock shiftlight, bulb works, how come it never lights?
and has anyone ever mapped the wires on the flat thing behind our gauge clusters? i need to know witch ones are witch for my new setup
heres what i have so far:
every one of the gauges has three screws connected to it besides mounting screws labled "e" "ig" and "u". exept for the tach it has "e" "ig" and "(-)"
top connecter (connecter 2 as labled on unit)
2-01 Goes to Brake light only
2-02 goes to oil (screw labled "e") and coolent(screw labled "e") guages and lights.
2-03 goes to alot of lights and connects to 1-03 prong.
2-04, 2-05, 2-06, empty.
2-07 left signal light
2-08 brigths light
2-09 right signal
2-10 goes to "u" screw on fuel guage
2-11 to an empty light that would be above the seatbelt light
2-13 ses light
2-14 shift light
bottom conecter (1 as labled on unit)
1-01 screw labled (-) on tach
1-02 goes to "e" screws on tach speedo and to some lights
1-03 connects to 2-03
1-04 goes to what would be a choke light.
1-05 goes to the "u" on the coolent gauge
1-06 goes to empty light
1-08 "u" screw on oil guage
1-09 "IG" screw on gas oil and some lights
1-10 empty
1-11 empty
1-12 goes to "e" screw on on oil and h20 and to ligths
1-13 seat belt light
1-14 goes to "s" on speedo.
if anyone could provide more light on this that would be super!
Old Dec 25, 2003 | 10:05 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Kinda reminds me of this post
when ever I brake down & get a printercartidge, I'll compare the 85 & 86 diagrams
Old Jan 1, 2004 | 09:16 AM
KED85's Avatar
I'm Waiting!
Old Jan 1, 2004 | 12:41 PM
Engine: 5.7 / 7.4
ok, differences between the 86 & 88 pin outs:
1) You fogot 2-12 & 1-07, not used anyway
2) 2-02, I have as 12V+
3) 86 1-04 you have for choke, 88 is for security ( neither one used most likely )
4) 1-12, 1-03, & 2-03 I have as ground/negative
now for 85 & 86:
I'll list the same wire pins/positions:
Top connector-
1) 2-05 & 5
2) 2-11 & 12
Bottom connector-
1)2-07 & 7
That's it. Everything else is relocated between teh two connectors.
edit: https://www.thirdgen.org/techbb2/sho...hreadid=216503
very good diagram of the 86 cluster, basically the same as the 88 I'm using. Props to Trickster for the link
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
R3500
Aug 17, 2015 12:16 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
