1227749 From a grand am?
I was doing a search on ecms and it looks like the 749 ecm was also installed in late 80's grand am's . Can anybody confirm this? Why is it that everbody says to look for a sunbird or syclone/tyhoon ecm?
Car: An Ol Buick
Engine: Vsick
Re: 1227749 From a grand am?
Anyway, yes it was used in other applications, at one of the syclone sites, they list all the donor cars.
It's just snazzier to say syclone rather then 91-92 FWD Quad 4 yada yada's. And the junkyard guys get tired of looking up yada yada's real fast.
Car: check
Engine: check
Transmission: check
Originally posted by anesthes
The '730 will work fine with the $58 code for your application.
-- Joe
-- Joe
RBob.
Car: 84 Z28
Axle/Gears: 9-bolt, 3.27
Why can't you run TBI with the '730? TBI injectors low imp?
-- Joe
-- Joe
Also, I think the couple years they put th e2.0 turbo in the Grand Am would also be a 749.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yup!
The output wattage is still the same, jsut gotta increase the amperage at a lower voltage right?
-- Joe
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I see.. So you'd need a couple transformers to use low imp injectors..
-- Joe
-- Joe
One of Ken's injector driver boards might allow using a 730.
BW
Car: An Ol Buick
Engine: Vsick
The 730 was used in numerous applications where they used saturated injectors. But, in only one TBI application, and it used just one P+H TBI injector, I say TBI P+H since TBI P+H's are 1.2 ohms resistance.
The 749 on the other hand was used in an 4 cylinder application that used P+H port style injectors, which are 2.4 ohms each for the 749 can be wired to fire 2, 1.2 ohm TBI injectors.
Transformers pass voltages that very, the *ON* pulse would not be transfer. So the injector might click on but then would shut off since there is no *holding* current. Not an EE explanation just trying to illlustrate transformers don't work very well on D/C, for passing low freqs.
88SS6SPEED
Nov 11, 2015 07:05 AM
