Here is my method for Polishing Tail Lights
Old Jan 12, 2004 | 11:47 PM
joshp14's Avatar
Well I am getting constant PM's asking me how I polished my tail lights. Here are some constant questions I get:
Q: Do I have to sand all of the tail light?
A: No. Only sand the parts that have blemishes. I sanded down the DOT lettering flush to get rid of the ugly things. WET sand this using 400 grit sandpaper on a sanding block.
Q: What do I need to do this project?
A: You will need a buffing wheel (loose style), plastic polishing compound from Eastwood, and something to mount the buffing wheel on...I.E.- bench grinder or a high RPM drill (1250+).
Q: What steps do I take to do this right?
A: Take your time when buffing. Pay attention to what you are doing. Be careful for heat build-up as it can happen quickly. Apply medium pressure as hard pressure is not required...let the buffing compound do the work. Wear safety glasses and no loose clothing. Work in a well lit area so you can see what you are doing. It may require going over it several times to acheive the results that I received.
Q: Can this be done on Camaro tail lights?
A: Yes, but I haven't ever done it before so I don't know if the steps are any different.
Q: How much are supplies?
A: Supplies will run you about $20. However, if you don't have a drill or bench grinder/buffer you may have to rent/borrow/buy one.
Here are the steps that I took:
1) Remove the tail lights from the car. If you look at the lenses, you will see raised DOT numbers. These have no use except for collecting dirt and wax, so I solved that problem. Take your 400 grit sandpaper on a sanding block, apply water to the lense, and in about 20 swipes the letters are gone and flush with the surface of the lense.
2) Wash the lenses with soap and water to get rid of any dirt or plastic particles.
3) Apply the buffing compound to the buffing wheel sparingly...once the wheel has started to change to the color of the compound, you have enough. You now have 2 choices when buffing:
A) Go slow and go over the surface once
B) Go fast and go over the surface several times.
*I chose to go slow...the only disadvantage with this is heat build-up. I didn't have a problem with heat build-up, but you may want to check every so often when you are doing it to avoid it.
4) Keep a clean terry cloth nearby so you can wipe away any compound build-up or particles/strings from the buffing wheel. If you start to get a rubber type residue on the lense, this signifies that you are using too much compound, so back off with the compound.
5) You can buff for as long as you want to...it just depends on how well you want it to look. I settled for what I have and they look like glass and took me about an hour of actual buffing.
6) Keep in mind that buffing is a project that requires time. If you rush through it, you will not get brilliant results. Also keep in mind that you do not need to apply much pressure at all when buffing, let the compound do the work, not your arms.
If you have any more questions, please ask and I will add them to the list and answer your question.
-Josh
Here are my results:
Old Jan 15, 2004 | 08:56 PM
Dark Man C's Avatar
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
Your taillights look awesome after the polishing...
Old Jan 23, 2004 | 08:57 PM
sikwitit's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 LB9
hey, tail lights look awesome by the way, i was just wondering, i polished my lenses as per your instructions, they look awesome too, i was just wondering what you did about the grid part... mine have dark spots in them, looks like water or air bubbles, that are underneath the grid, is there neway to make the grid part look like the lenses? thanks, mike
Old Jan 25, 2004 | 11:23 AM
88IROCARMY's Avatar
Warning about buffing
Hello
Just a warning when using bench grinder or drill mounted wheels for buffing. Excessive buffing wheel speeds will build heat causing the plastic to melt/discolor. Ensure that you use the fluffy wheel as mentioned earlier. Also ensure the wheel is not caked with polishing compound, this will cause heat build-up. Keep the wheel moving and do not apply alot of pressure. I made these mistakes and I have one taillight that has melted. The melting occurs very fast and is irreversible. Take it slow and easy-enjoy the results.
Just another reminder
Old Jan 25, 2004 | 04:58 PM
The Doc's Avatar
Many thanks for the instructions Josh! I'll think I'll do this soon.
One thing, could you possibly post 'before' pics for comparison please?
Old Jan 25, 2004 | 08:35 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
That looks extremely well done.
I have a question. Would it be possible to use something such as a dremel tool to buff the tail lights instead of a drill or bench grinder?
Old Jan 25, 2004 | 10:05 PM
joshp14's Avatar
If you can figure out a way to mount a buffing wheel on a spinning tool, by all means go ahead. Just as I said in the first post, I can't stress enough about heat build-up. It comes very fast if you aren't careful...so BE careful.
sikwitit...I'm not exactly sure what you mean...
I only have 1 before picture...here it is along with the after picture in the next post:
Old Jan 25, 2004 | 10:06 PM
joshp14's Avatar
after...
Old Jan 26, 2004 | 01:39 AM
88IROCARMY's Avatar
joshp14
I just want to let you know that my melting incident happened about a year ago and not after following your post. Just letting you know.
Old Jan 26, 2004 | 08:54 AM
85TransAm406's Avatar
Car: 1985 Trans Am
i think he's saying that the grid is separating from the lense. Mine are doing that too, i'm on my 3rd set of used taillights, and i was about to polish them when i saw them separating. I just can't figure out how to fix the grid part.
Old Jan 26, 2004 | 03:32 PM
joshp14's Avatar
Ohh, mine isn't doing that so I wouldn't know how to fix it...:shrug:
Old Jan 28, 2004 | 08:23 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Most likely a clear adhesive to put behind it to glue it back on. Just pull it out completely and glue the entire thing back on. Maybe something such as leaving it out all together may work. But mine are doing the same thing so I’m going to have to look at them.
Old Jan 29, 2004 | 11:59 AM
sikwitit's Avatar
Engine: 305 LB9
hey kidrcth, if that works, please let me know how you did it, i took the tail lights off, and it looks like the plastic is kind of layered on top of the grid... the only way i could see to get it out would be take it out in pieces, such as redraif did i believe... but i really dont want to go rummaging for new tail lights, so if you get yours out, pm me or something, cuz that would be great, thanks, mike
Old Feb 28, 2004 | 01:31 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Dude I am doing that to my 91 T/A tail lights, Luckily I have some cracked ones to practice on.
Old Mar 12, 2004 | 08:22 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
No actually the grid is painted on the inside of the outter piece of plastic. The same goes for the center section. I know because when i took my center section off i could see the paint peeling on the inside and i tried to repaint it. It looked brand new for 15min until the entire thing shriveled up and looked like ***. Now i have to get a new one. Moral of the story....
LOOK AT THE CAN BEFORE YOU SPRAY, PUTTING LAQUER OVER ENAMEL WILL CAUSE THE WHOLE THING TO DISSOLVE
Ive been working with this kind of stuff way to long to make a dumb mistake like that. Stupid me
Oh well, its off to Ebay i go...
Repainting it will make it look great if you use the right kind of paint
Old Mar 18, 2004 | 09:00 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
i always wondered if that worked well or not..
Finally did it on my 3rd brake light so far.. really came out great!
BEFORE
Attached Thumbnails Here is my method for Polishing Tail Lights-3rdbrakelightbefore.jpg
Old Mar 18, 2004 | 09:01 PM
Engine: 7M-GTE
Transmission: R154
After!
Attached Thumbnails Here is my method for Polishing Tail Lights-3rdbrakelightafterpolish.jpg
Old Mar 18, 2004 | 09:45 PM
joshp14's Avatar
Good work my man! It's very rewarding isn't it?
Old Mar 18, 2004 | 10:48 PM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
the tailights look awesome man i have buffer that i bought from sears to buff my car with but i dont think it has that high of rpms could you point me in the direction of a good buffer to use
Old Mar 19, 2004 | 02:14 PM
Engine: 7M-GTE
Transmission: R154
yeah... I've been polishing wheels for a while now, but i just love the way my lights are turning out.. i'll have to post a few pics of the camaro taillights whenever i get mine done...
Old Mar 21, 2004 | 02:14 PM
TheNutzZ28's Avatar
Car: 89Iroc Vert, 86 Iroc/Z28
Engine: 383carb, 350 TBI
Transmission: Th350, 700R4
Axle/Gears: 3.23 posi disk, 3.42
wow thoses are some nice results, I'm going to have too try this when it gets nicer out, crazy wisconsin weather....
Old Mar 21, 2004 | 09:51 PM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
awesome results, what kinda ginder did you use? i want something handheld, instead of a bench ginder. what do you recommend?
Old Mar 21, 2004 | 11:25 PM
joshp14's Avatar
I'm not sure what other kind of buffers you can use. Just make sure you have a drill with high RPM's and a buffing wheel that mounts on it with the plastic polishing compound.
I used the bench grinder cuz you can take the lights off of the car and get every nick and crevice instead of just the main part of the lense.
Old Mar 28, 2004 | 07:44 PM
Engine: 7M-GTE
Transmission: R154
for all you Camaro owners.....
got around to doing the taillights.. I really wish i did a before pic, because they came out great!
Attached Thumbnails Here is my method for Polishing Tail Lights-taillightbetter.jpg
Old Apr 3, 2004 | 01:15 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Hey 86IROCKET-Z,
Did you follow josh's instructions or did you do anything differently. I just bough a pair of the same camaro lights and plan on polishing them, so i was just wondering if anythign was different, thanks.
Old Apr 4, 2004 | 08:22 PM
Engine: 7M-GTE
Transmission: R154
400 wet, 600 wet, 2000 wet..
buff it out.. do the black part to.. it really brings it out beautifully.
I used a thin rubber block.. 3M makes it.. worked really good..
The picture does it no justice at all..
:lala:
Old Apr 6, 2004 | 11:33 PM
joshp14's Avatar
I tend to stay away from doing the sandpaper method as it takes more time. Let the polishing compound do the work.
Same goes for polishing aluminum, stop at 400, no need to go any farther, then go to the polishing compounds. Turns out better than the sandpaper method anyway IMO.
Old Apr 7, 2004 | 08:37 AM
Engine: 7M-GTE
Transmission: R154
I have seen much better results by going to an even finer grit than 400. It looks great if you ask me. Done a few different sets of wheels, and you can always get rid of those annoying finer scratches on the wheel with something like 600 or 1000.. Feels like glass.. It all depends on how much time you want to spend on it.
Just my 2 cents
Old Apr 18, 2004 | 12:57 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
:lala:
So did you do it entirely by hand? I'm a little confused on this.
Old Apr 19, 2004 | 08:44 PM
Engine: 7M-GTE
Transmission: R154
nope, After wetsanding 2000 I got polishing compound out and I have a polisher (kinda like a mini-buffer), which I used to polish out the taillights.. I'll get a pic up of it tommorrow.
Old Apr 30, 2004 | 10:25 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I did the methods stated above. I have to now look for a new left taillight assembly. I did the wet sanding (by hand) and polishing (both by hand and machine) and neither helped. In fact it looks even more cloudy and scraped up.
Old May 9, 2004 | 09:28 AM
joshp14's Avatar
Well you must have done something wrong because If you follow the instructions above, you will have the same results. You said you polished by hand....with a polishing compound paste? What steps did you take?
Old May 9, 2004 | 11:47 AM
NEEDforSPEED's Avatar
joshp14, what about these?
i have my own methods...
what you think?
Before and a after...
Attached Thumbnails Here is my method for Polishing Tail Lights-beforeafter.jpg
Old May 9, 2004 | 09:32 PM
joshp14's Avatar
what you think?
Looks good...comparable to mine ...actually looks like you polished for a few extra minutes. What is your method....if different than mine?
Old May 10, 2004 | 10:45 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I used Mothers Wax metal polish and Eagle one on mine....
Old May 26, 2004 | 12:26 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
what you think?
Wow, those look sweet! How much for me to mail mine to you and you make 'em pretty?
No. really. I'm totally serious. I haven't the patience to do it myself. PM me if you're game!
Old May 30, 2004 | 10:27 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
joshp, is it alot better to use a bench grinder when polishing taillights? I am using a drill right now and they shine great but I think I could do better. Would it be worth it to get a bench grinder? What is the average amount of time you spend on a taillight? Thanks.
Old May 31, 2004 | 07:36 AM
joshp14's Avatar
Well, if you think they can shine more via other methods, then by all means go right ahead. Hell you can get bench grinders for like $20 now. I haven't ever used the drill method, just heard about it. Although I like the fast, immediate results that a bench grinder gives, rather than the continuous work of using a drill (or so I've heard).
Only thing with the BG is, you are spinning about 2 times the RPM's as the drill, so the heat build-up is significant and must be observed otherwise you will have some melted tail lights. As long as you dont apply much pressure, and move the wheel at a moderate speed across the surface of the lense, you should be ok.
Old Jun 10, 2004 | 12:20 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i have black outs on my firebird and somehow someone scratched the passenger side blackout would this polishing technique help get rid of my ugly scratch
Old Jun 10, 2004 | 07:28 PM
joshp14's Avatar
If the blackouts are plastic, then I assume it will work. Use this polishing method for surface scratches only....it won't take out scratches that you can feel.
Old Jun 10, 2004 | 07:45 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
what is a good way to clean buffing wheels?
Old Jun 10, 2004 | 10:30 PM
joshp14's Avatar
They actually make a buffing wheel cleaner on Eastwood. You may be able to pick one up at a local hardware store too. It looks like a brush, only with very stiff metal brissels.
Old Jun 10, 2004 | 11:23 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
this is probabbly a dumb question
those are some darned nice looking tail lights. when you say use a drill buffer, what do you mean? like a cordless drill then some kind of buffing pad (that goes in like a drill bit)? I would really like to get my lights to look that nice (well first I need ones that aren't cracked to hell and back). anyway thanks in advance
Old Jun 11, 2004 | 01:49 AM
joshp14's Avatar
Re: this is probabbly a dumb question
Exactly. Go to Sears and ask where the buffing wheels are. You can buy a small package for like $6 that comes with 3 buffing wheels, an arbor, and like 4 buffing compounds ( for metal polishing, not plastic). Then you will need the blue plastic polishing compound from Eastwood Co.
After you get those products, just read my directions above.
Old Jun 22, 2004 | 01:21 AM
redraif's Avatar
Transmission: Th700R4
The grid in the taillights I worked with was acually a separate plastic piece that was adheared to the clear lense. I actually had a heck of a time getting it out. I would be careful removing it if it has not natually separated, or it might crack the clear lense.
The center sections are painted though.
Old Jun 22, 2004 | 01:25 AM
redraif's Avatar
Be careful w/ a dremel...it has a much smaller surface area and tends to heat plastic up quick. I tried this method a long time ago on my trucks tailights and melted a small area. Plus it will take longer and be harder to get an even finish.
Old Jun 27, 2004 | 05:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hey i decided to finally take on this task, but can i ask, what is the alternative to meguiars plastic polish?
Old Aug 23, 2004 | 02:32 AM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Just a tip for everyone I used 3M rubbing compound and it also worked wonders to remove very fine surce blemishes and made my grid taillights look like they just came from the factory. for deeper blemishes wet sand with 2000-1000 grit sand paper, then step down to mothers mag polish, then use a plastic polish like mcguires no 7 mirror glaze. the mag polish is slightly more abrasive than the mcguires and works into the lense a little deeper to remove blemishes. Keep in mind this works on taillights, plastic taillight covers, side markers, plastic fog lamp lenses, instrument cluster lenses, i even polished up the center console clock on my 83 Z! but like everyone else sates, WATCH FOR HEAT BUILD UP! good luck !
Old Sep 5, 2004 | 11:59 AM
BigNg's Avatar
Car: 84, 86
Engine: 84 w/V-6, 86 w/305 V-8
Transmission: both auto
Do you think this procedure would work for the gauge lens? Its a lot softer plastic than tail-lights. I picked one up at the wrecker, a bit scratched up, but I didn't have one at all (as the guy swapped out the speedo and never replaced the lens)
Old Sep 5, 2004 | 12:58 PM
Engine: 7M-GTE
Transmission: R154
yes.
I did this with my gauge lense, but i would not go with a grit any heavier than 1000.
you have to take it out and wetsand for quite a while, and then polish.
I also used windex on the lense before putting it back in, to make sure it was clear as could be.
