New intake and misc..
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Thought I'd pass along a few shots of the intake and fuel rails. Also the blower belt layout is completly redone..
BW
BW Thread Starter
Car: 84 SVO
Transmission: WCT5
Originally posted by stevedave454
what is the lower manifold? looking good, i like home-built s**t, when its all said and done you can take more pride in something you did yourself
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by SATURN5
A crossfire lower... also waiting on a vortec truck lower intake.. similar in style.. BW
so did you hog out thoes tiny intake ports or what?
looks like its coming along great..
Car: 84 SVO
Transmission: WCT5
Going to see if the vortec intake is feasable before I go grinding the crossfire.
I hope it is since vortec heads are much better than the normal GM stuff and cheaper than hacking a stock set, or going aftermarket.
thanks, Bob
Car: 1992 B4C 1LE
WOW! my parents had one of those! the guy used to put our mail in it. just kidding.
ok-ok Im not just PH'ing here, I really like the idea.
wish I could weld aluminum
Car: 91 Camaro Vert
im making my intake version 1.0 out of steel... between the intake and blower, its going to be HEAVY.but im sure im going to be doing somthing like SATURN5 and swap and change the setup around as i go along.
Car: 1992 B4C 1LE
BTW, what the heck lower manifold is that?
Car: 91 Camaro Vert
heres a pic of what it looks like stock (kinda):
Car: 1992 B4C 1LE
I was thinking it was but couldnt identify it for sure.
wouldnt those require alot of porting to get a "fullsize" post since they are cast half closed? also the runners inside would have to be cut as well right?
Car: 84 SVO
Transmission: WCT5
BW Joined: Jun 2001
Huh… when you told me about it somehow I thought you were going to use that intake and convert to an M112.
I'm not sure I get it. Is that just a second plenum chamber up top or is it an intercooler or something? It appears that you're laying it out with 2 connections to the crossfire plenum?
How did you get that base so clean???
As a side note, I finally got my TA towed to my garage so I can take it apart and get rid of it. I tried outside but it's too cold and snowing… First thing I did there was pull the crossfire intake so I can modify it for my truck
BTW, a die grinder won't let you do anything to the ports but open up the surface that mates to the head. If you look at the under side of the crossfire casting you'll see that there is no meat to grind into more then about an inch into the port, and if you really wanted to open it up there you'd first have to fill it in from underneath. FWIW, I think that blocking off the bottom side of the port entry on something like an L98 head wouldn't hurt and may actually help.
If you get your hands on an vortec intake do me a favor and get some good pictures of it… I'm still trying to get a good impression of what the deal is with it and if it's got potential for some cool fangling…
Car: 84 SVO
Transmission: WCT5
I'm just going to add volume with a larger "upper" plenum, rather than stack up the lid. Thats how the lower came, tho a soda blasting will clean them up nicely.
I'm more conserned with port matching than hoggin the ports, since its boosted, they don't need to be huge.
I'll get you some pics once it gets here. From the few I have seen, it's like a crossfire, with possibly less internal volume. BW
Car: 84 SVO
Transmission: WCT5
Originally posted by 614Streets
Doesnt your belt slip? Does not look like the belt can handle the load.
Car: 91 Camaro Vert
*crosses fingers*
my only forseeable problem is how far forward i have to have the blower to clear the stock surp belt.... unless i decide to run it off the stock belt.... but then the pulley on it blower is almost twice as wide as the stock surp belt... id kinda like to take advantage of the wider pulley. so that means i run a diff belt infront of the stocker...
Car: 84 SVO
Transmission: WCT5
Originally posted by anesthes
I think he went with a HSR
-- Joe
-- Joe
The crossfire intake is getting a new lid, a 2bbl TBI unit and is gong into my truck.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yup.... HSR.
Yup.... HSR.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by jrg77
So you drill hole in the single plane intake for the injectors, make fuel rails, and what do you use for the throttle?
Jason
Jason
-- Joe
Car: 84 SVO
Transmission: WCT5
Don't like my Singleplane setup, Bob?
-- Joe
-- Joe
Car: '85 Camaro
Engine: LG4 305
So the vortec throttle-body bolts up, or do you have to makean adapter plate?
Since you aren't using a carb how do you hold the air cleaner?
Forgive me if the questions are too plebian, as I have never seen the throttle body.
Jason
Jason
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Jason
Jason
I used a "vortec" hat. You can use the stock mounting clips but I was afraid it would leak boost/blow off, so I used metal strapping for now.
-- Joe
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
