Car left me stranded for the 3rd time last night
Old Feb 23, 2004 | 09:15 AM
lucas's Avatar
88 Camaro 305 TBI. My problems all started when my car would not crank over. It was traced down to a bad connection on the negative battery cable. Since then I have been having trouble with the car intermittently dying on me. When idling the car is fine, I go to drive it and for a while it works fine. The car will start to hesitate, surge, backfire, and misfire until it dies completely and refuses to start for 30 minutes or so. It cranks over fine, might start for a couple of seconds, then dies. If I wait 30 minutes I can limp it back home sometimes, sometimes it takes up to a day before I can get it back.
The shop had trouble putting the scope on it because it was so intermittent, it will happen only while driving, not idling. They said when it does happen the secondary ignition is failing but they can't rule out the primary ignition. They said fuel pressure was fine.
I replaced the coil with a Wells unit from autozone, worked fine for about 4 days then died on me again with the same symptoms.
I then replaced the entire distributor with a rebuild that included a new module/pickup coil. No change.
I replaced the coil again with a Borg/Warner unit thinking maybe the Wells coil crapped out on me and the car worked for about 5 miles until it died again.
I think I blew a fuse for my interior lights/radio the same time I initially had trouble with this stuff, not sure if that is related.
The car drives fine when its working, bu t becomes undrivable when something in there heats up.
Old Feb 23, 2004 | 11:31 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
wires and plugs good, try dooing a ohms reading on your wires, and makesure your plugs arent rounded off. they may be requiring too much voltage and frying your coil
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Fronzizzle
Aug 9, 2015 01:15 PM
