wanna make a set of subframe connectors
Old Feb 29, 2004 | 08:07 PM
84v6bird's Avatar
Car: 1982 firebird
Engine: 267 with full dual exhuast
Transmission: th350 with shift kit
i have a 84 firebird and i wanna make subframe connectors but i have no cule where to start with this. where are the subframe rails that im trying ot connect. when i look under my car on the front i see 2 things that could be sub frame but i wanna be sure about this and the back which do i go to. does any one on here and a diragrame i can look at with sizes and stuff. or maybe someboyd bought some and can take some pics for me and size them so i can make cheap set
Old Feb 29, 2004 | 09:16 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
welcome to the boards.
if you do a search for "sfc" or sfc's" you will get plenty of pics and advice.
Old Mar 1, 2004 | 07:52 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
they bolt in the back and actually use the bolts that hold the trailing arms in. then they run up the sides of the car, flush with the body and depending on the brand they either weld to the floor right before the wheel well or weld to the tiny piece of frame there is under the car.
yes do a search for it. there is a picture of an fbody laying on its side and you can see the frames and the whole bottom of the car. best underbody picture ive ever seen
Old Mar 1, 2004 | 09:22 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Attached Thumbnails wanna make a set of subframe connectors-under-side-view-f
Old Mar 1, 2004 | 09:50 PM
Kontrax's Avatar
Car: 86 Camaro
sick dude, just absolutly SICK. how the hell is that car sitting like that LOL
Old Mar 1, 2004 | 11:15 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Its on a rotisary, their pretty cool.
Old Mar 2, 2004 | 01:27 AM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I'm trying to get my hands on one of my dad's pals rotisserie so I can do the underside of my car while it's all torn apart. Too bad you can't do the SFC's while it's on one.
Old Mar 2, 2004 | 02:17 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Forget the Alstons in this pic for now... I made mine like shown..
minus the alstons.. I used a torch.. (much easier than cut bend weld) .. driver side.. its easy.. 1 straight piece.. pass side needs a little tweak.. you'll see when you get under the car.. I used a coat hanger to get the angle.. then measured where to put the bend.. then heated up the metal and slowly bent it. 1 bend was perfect .. the other I kinked it in a little and i put a small patch on it for structural support.. bend looks like this in essence
\ ________
I used 2"x1" tubing 1/8" thick (more than adequate.. ) PS use a mig. the 2x1 fits just right.
Attached Thumbnails wanna make a set of subframe connectors-my-subframe-connectors.jpg
Old Mar 2, 2004 | 07:18 PM
84v6bird's Avatar
Car: 1982 firebird
thanks alot guys that has help me understand this alot better.
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Andrew6.688
Dec 13, 2015 10:59 AM
perZ
Aug 15, 2015 01:17 PM
