Dynomax cat back system and new cat
Old Mar 1, 2004 | 05:01 PM
3rdgenstm's Avatar
Car: ‘92 Z28
I installed this yesterday in about 4 hours. For those of you who have bought one and have yet to install it or those who are thinking of buying one, here are some tips.
(If you don't have a lift or access to one).
1) Make sure the *** end of the car is as high as you can get it. My jack doesn't have enough lift, so I had to put it on blocks to get it to match the highest setting on my jack stands.
2) It may seem like a PITA, but remove the rear sway bar and panhard rod. The one piece intermediate pipe won't fit over the axle unless you do this.
3) Have some extra 3/8" hardware around. I don't know if my kit wasn't fully stocked with hardware or they don't provide it, but all I got was 3 exhaust clamps. It is a lot nicer to replace all that old rusted crap with nice, new stuff. I used some exhaust manifold studs to connect the ball and socket joint at the cat-- looks nice.
4) They don't provide a new tailpipe hanger on the passenger side. The stock one is welded to the tailpipe. Auto Zone has a replacement. I haven't gotten one yet, but I just tightened the hell out of the clamp.
5) You will have to drill out the driver side tailpipe hanger bracket to thru bolt it or you will have to tap it and find a bolt to match. I drilled a clearance hole and thru bolted.
6) Don't fully tighten anything until you are sure that is where you want it.
Overall, it was easy to do. You will need a buddy to help manipulate the pipes, hold them in place, and hand you tools. If I knew these tips before hand it probably would have taken less time. I had to stop and find hardware, figure out how to get that pipe over the axle, stuff like that slows you down. I also had to get my old pipes and cat off and install a new cat. I will post some pics later.
See ya.
Old Mar 1, 2004 | 10:51 PM
KYL98's Avatar
Car: 1991 Z28
Re: Dynomax cat back system and new cat
Overall good right up....I had the same problems mentioned above on my Dynomax catback....is your's 3in? Only different thing I did was have a buddy raise the car up in the back(lift up on the bumper with his hands) and I slide the Ipipe over the axle. I was gonna resort to what you did...or pay somebody else to do it...but luckily that worked. The muffler will sound better in about 2-3mths...after its broken in.....good luck
Old Mar 1, 2004 | 11:56 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I think the largest one-piece I-pipe in the complete cat-back is 2¾", just the two-piece ones are 3".
What I did when installing my one-piece pipe, was to make it into a two-piece by cutting it on the straight section that goes up to the over-axle bend, and join it with a coupling. Much easier than trying to wrestle with the one-piece pipe.
Old Mar 2, 2004 | 08:53 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
I never knew there was a tailpipe hanger on the passenger side. I thought the hanger on the intermediate pipe supported that side, while the driver side tailpipe hanger supported that side of the muffler. I never had to drill anything, the driver side pipe bolts right up to the existing rubber strap. What car did you put this on? Are you sure you got the right exhaust?
Old Mar 2, 2004 | 12:11 PM
3rdgenstm's Avatar
Car: ‘92 Z28
There was a hanger on the pass side on the original system and I am not gonna trust that tailpipe to stay in place just with the clamp. I bought and will weld a new hanger for that tailpipe. There is a hanger on the intermediate pipe, but it doeesn't 'support' the tailpipe.
I had to drill out the hole in the bracket welded to the driver tailpipe because I used new hardware and made it all the same size. A 1/4" bolt should fit back thru the hole just fine. The system that was on my car (I assumed it was factory by the looks of it) had a bracket welded in the same spot, but the hole was tapped. The Dynomax tailpipe wasn't tapped, so I drilled it and thru bolted.
I'll try to take and post pics tomorrow.
Old Mar 2, 2004 | 12:12 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Oh yeah. I also used some Hi- temp nickel anti seize on the connections.
Old Mar 3, 2004 | 07:33 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Heres 1 pic of 4
This is just a shot of it from the rear.
Old Mar 3, 2004 | 07:34 PM
3rdgenstm's Avatar
Car: ‘92 Z28
This is the driver side hanger and thru bolt on the tailpipe
Old Mar 3, 2004 | 07:35 PM
3rdgenstm's Avatar
Car: ‘92 Z28
This one is the cat
Old Mar 3, 2004 | 07:37 PM
3rdgenstm's Avatar
Car: ‘92 Z28
This is the passenger side hanger I installed. I welded it at work after I took these pics.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
