Long Tubes to single exhaust
Old Mar 3, 2004 | 08:36 PM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
Ok I got long tube headmen headers and magna flow cat-back exhaust. will this all hook up or with a bent Y pipe to take both long tubes dow to the single exhaust?
Old Mar 3, 2004 | 11:37 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
it can be done easily by a good muffler shop!!!!!!!! it will look better if you spend 40.00 on the flomaster y-2.5 dual in and 3 out.
Old Mar 4, 2004 | 07:57 AM
I RoC A Z's Avatar
Where is a good place to buy one of those Y pipes?
Old Mar 4, 2004 | 12:28 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
What a lot of guys are doing w/ the Hedman LTs is getting 2 S X-tentions from and a Flowmaster Y Collector from a place like Summit or Jegs, and then getting a shop to do the rest of the piping from there. The S-Xtensions will get the pipes down from around the subframes and allow you to bend pipe around to the flowmaster Y collector.
Old Mar 4, 2004 | 03:28 PM
biff85ta's Avatar
Car: 04 Vette
I can get some pics of my setup if you would like.
Old Mar 4, 2004 | 03:54 PM
1986camarojoe's Avatar
Car: Z28
Engine: 310
I'm thinking about doing the same thing, pics would be great.
Old Mar 4, 2004 | 07:17 PM
I RoC A Z's Avatar
Yeah pics....
Old Mar 5, 2004 | 02:00 PM
biff85ta's Avatar
Car: 04 Vette
Let me know if you need something else and I'll see what I can do.
Old Mar 5, 2004 | 02:01 PM
biff85ta's Avatar
Car: 04 Vette
Here is the ground clearance I have.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
DIY PROM
Aug 20, 2015 06:44 AM
