motor just rebuilt, big problems
Old Mar 12, 2004 | 02:20 PM
RocZ57's Avatar
The motor was just rebuilt with the following mods to a 90 350 tpi.
dart iron eagle 165 cc heads port matched to the edelbrock headers, comp cam pro magnum roller rockers 1.52 ratio, mid-high 9's compression from trw forged pistons and gaskets, .488/.495 212/218 comp cam 112 lsa, edelbrock ceramic headers, random tech cats, borla exhaust, siamesed 3.25" base, KN, ported plenum, 24 lb/hr injectors 2600 stall.
The car turned over and started. However, it won't idle for it's life. The throttle must be held open slightly for it to run. Datalogs were taken and it runs extremely lean, loads of spark, not enough fuel, much timing retard.
The distributor is set to tdc on cylinder one. Even base timing was set to 6 degrees advance and there's still no luck.
The number 7 header tube glowed once with the car running. I'm running out of ideas.
Valve lash was done. I pulled the driver side valve cover and the springs go up and down normally.
Does anyone have any specific tips such as a particular wire to check, or sensor, etc?
Old Mar 12, 2004 | 02:22 PM
CamaroMike's Avatar
FIRING ORDER, INTAKE LEAK, TIMING, FUEL PRESSURE TO START!!!!!! Check this first and watch her purrr.........
Old Mar 12, 2004 | 05:01 PM
ede's Avatar
ede
think i'd add run the valves or juts back them off a turn or so. the glowing header tells you it's either real lean or fuel is burning in the tube.
Old Mar 12, 2004 | 09:41 PM
3rdgenstm's Avatar
Car: ‘92 Z28
Back the valves off 1/4 turn at a time, check the firing order, timing.
Old Mar 12, 2004 | 11:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello RocZ57,
You have a PM!!!!!!!!!!
Old Mar 14, 2004 | 03:50 PM
RocZ57's Avatar
What kinds of tests are there to test fuel injectors? I'm wondering if I might be running a bad injector. What do you guys think?
Old Mar 14, 2004 | 04:38 PM
RocZ57's Avatar
I got 171 psi for compression on cylinder one. I can continue on the other cylinders. Does compression have to do with the valves being turned too much
Old Mar 14, 2004 | 10:29 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
If you have a valve hanging open from an over tighten rocker a compression test will show a lower psi on that cylinder.
Old Mar 15, 2004 | 06:37 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
How does the motor rev? My bet is either rockers too tight, way too advanced or retarded timing, or a fuel delivery problem ...all in that order.
Old Mar 16, 2004 | 10:02 PM
plumminfool's Avatar
Car: 1988 camaro sport
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
glowing header pipe is timing advanced too high. experienced that one myself.
Old Mar 17, 2004 | 09:44 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
i had the glowing headers. i called edelbrock because it was their cam and lifters i used for a basic cam swap. they told me that since i used a cloyes timing chaing that the timing was set differently causing the cam to be out of phase or something like that...it was 4 years ago. so i had to bust up 50 bucks for the correct EDELBROCK timing chain. point being i would check your timing. also readjust the rockers if all else fails. like stated that can cause a hanging valve.
Old Mar 17, 2004 | 10:13 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Retarded timing and/or lean mixture will cause this.
Old Mar 18, 2004 | 09:44 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
well
This may help because no one could help me when I had the problem. Mine would start and slowly start to die. Now I was **** and replaced the pump, lines, rebuilt the regulator, everything based on what people said. Now what it was, was the knock sensor was unhooked. The engine would get pump primed when I turned the key to accessory which brought enough fuel to start and run the car for a while, but when the pump determined that there was no knock or oil sending unit the pump wouldn't keep the egnine running as a safety feature.
Also TPS, and CTS sensors might be one problem.
Old Mar 18, 2004 | 11:42 AM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
Umm, not sure, but you already told us the problem in the first post. "extremely lean, loads of spark, way retarded"" .........THATS WHY ITS RUNNNING LIKE A YUGO You'll probably need a chip or something so the computer knows what the hell is going on....
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
st.evel07
Aug 13, 2015 06:15 PM
