Hawks' Five-Inch Spoiler Installed.
Old Apr 2, 2004 | 01:49 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
First off, the fit and finish as I received it is good. It did require sanding. Nothing out of the ordinary for a fiberglass piece.
This spoiler is listed as a direct bolt-in for non-third brake light spoiler Camaros. Don't let that discourage you if you have a third brake light. If you're willing to make a couple of minor mods, it's not that hard. The two center studs on the center piece are in the wrong position. They need to be moved outwards. I did this by cutting off the two studs, cutting an access slot on the underside of the spoiler for the two new studs, drilling two new holes and sliding bolts in from the backside, The two side holes in the quarter panels for the side pieces need to be reamed out slightly towards the rear of the car. The top hole cannot be used -- too far forward. Drill 3/8" holes about 1-1/4" behind the existing holes. That's it!
Because I have a third brake light, I decided to take it once step further. Since I already had to cut an access slot, I installed a 48-LED light bar, a la Cadillac. This took a lot of time and patience and several different ideas (and trips to the hardware store!) to get it right. The back surface between the LED's is mirrored and I made a clear lens. In the future, I might try smoked or maybe even a red lens.... In either case, the finished product came out relatively nice. Sorry, I don't have a closeup of the light bar yet. Suffice it to say, with my cowl hood, the spoiler looks good..... now maybe some heritage striping???
Old Apr 2, 2004 | 01:54 PM
CaysE's Avatar
HOORAY! It's good to see a plan go from start to finish over the course of a few years.
Old Apr 2, 2004 | 02:15 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
looks great from every angle but the back from the back it looks bad imo not the light in it just the size looks bad
Old Apr 2, 2004 | 02:33 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
just my opinion, i dont like that spoiler at all
Old Apr 2, 2004 | 03:35 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Is it just me or does the LED brake light seem to go just a tiny bit farther to the right than the left? It looks good tho, especially from the side.
Old Apr 2, 2004 | 03:45 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I think it's just the angle. Looks good though..........but it's missing something. Oh I know... the Supercharged 305 sticker. Good job Willie.
Old Apr 2, 2004 | 03:56 PM
KillerRS's Avatar
IMHO that spoiler sucks
Old Apr 2, 2004 | 04:11 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
The side view of that spoiler looks kick ***!! The led light bar is nice looking too but it kinda looks too slim for that spoiler. Either way though I think it looks great. Thanks for the pics!!
Old Apr 2, 2004 | 04:40 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Too be honest I am not a fan but its a nice custom job!
Old Apr 2, 2004 | 05:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Awesome!!!
Looks like the spoiler on my dad's old '73 Z28!
Old Apr 2, 2004 | 05:09 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
The LED bar looks centered properly to me. Follow the edges of the LED bar straight down and you will see that it is even with the tail lights on each side.
I think it looks sweet.
Old Apr 2, 2004 | 05:25 PM
nolanr0413's Avatar
Car: Trans am
i like it, if i wasnt getting rims and tires this year i would get one for my trans am . I would have someone mod the side pieces so that it would look good on a ta. I think hawks should work on one for a ta. I like it, they shoulda come from the factory with a spoiler that big.
Old Apr 2, 2004 | 05:26 PM
Willie's Avatar
The light bar is centered. I made absolutely sure it was before cutting. It shows up not true because of the angle in which I took the pic.
It does resemble the second gen spoiler but I did not realize until after I installed it that there is one difference. The rear surface of this spoiler, although slightly curved, is basically flat. I don't like this. It's too flat and makes the spoiler look like a billboard!! It doesn't help that my car is white (bland color). Just makes it look that much worse, I think.
The second gen spoiler has a lower and upper sections which are at an angle to each other. So in order to make it look acceptable, I'll be changing the color on the lower section. I'm trying to visualize how gloss black would look on the lowest one inch or so. It would make it "appear" to be part of the black taillight section. Experimentation with some wide striping tape is in order! Just happen to have a one-inch wide roll of gloss black..... Now if it would just stop raining....
Willie
Old Apr 2, 2004 | 06:24 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
nice job!
Old Apr 2, 2004 | 06:31 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
That looks wicked cool. If I had a maro that'd be my spoiler of choice for sure!
Old Apr 2, 2004 | 08:40 PM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Same here. Looks good!
Old Apr 2, 2004 | 10:09 PM
rusty rider's Avatar
Car: 86 IROC
Engine: 305 lg4
That thing looks AWSOME:hail: :hail:
Old Apr 3, 2004 | 01:17 PM
Sir Speed A Lot's Avatar
Car: 1984 Trans Am
Engine: 305 LG4 :(
Transmission: 700r4 :(
looks like hell im IMHO
Old Apr 3, 2004 | 02:26 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Oh man thats hot. It would be cool if you did like a transparent white over the third brake lense so it wasnt noticable unless lit up.
Old Apr 3, 2004 | 02:37 PM
Mavrick's Avatar
Car: 91 Camaro RS
Welcome to NASCAR
Old Apr 4, 2004 | 11:59 AM
Willie's Avatar
This spoiler is like rear window louvers; you either love it or hate it.
It didn't come out as I'd hoped. From directly behind, the thing looks like a whitewashed billboard. So, I've been playing around trying to not make it look so huge, playing tricks with colors. I like it better now (subject to opinion of course).
Yes, it would be nice if I could use a transparent white lens but doing so diffuses the LED's so much that I don't like it. With my newest change though, it doesn't stand out as much.
Here's what I came up with:
Old Apr 4, 2004 | 12:00 PM
Willie's Avatar
.... and a closeup of the light bar:
Old Apr 4, 2004 | 12:10 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
I like it!! Install is nice and clean... GREAT job!!
Old Apr 4, 2004 | 05:33 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I'm a 'stock ****', but I think that looks pretty badass. Light bar is sweet too.
Old Apr 4, 2004 | 08:11 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I dunno, I just think that spoiler looks weird. Not really bad, just weird. Just my opinion though
Old Apr 4, 2004 | 09:46 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Spoiler does look out of place, but the LED's look sweet. Very nice install.
Old Apr 4, 2004 | 11:03 PM
Thirdgeniroc's Avatar
Car: 86 iroc
Engine: 355 TPI
Looks sweet to me nice job!
Old Apr 5, 2004 | 02:11 AM
CrazyHawaiian's Avatar
Car: too many ...
I think it looks great!
Old Apr 5, 2004 | 04:43 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Hell yea baby expecting mine sometime this week. Until i get the car painted mine isnt going to be the stock color i'm either doing it black, silver or a teal thats fairly close to stock. I love it looks sexxier than **** cant wait to get mine.
Heres a question? The holes that didnt work. Did they not work becasue of the position of the third brakelight in comparison to the stock holes. Its meant for non third light camaros so i wonder if i will have post-hole problems or if it will slide right in. Looks good bro thanks for getting us the gp on these:hail:
Old Apr 5, 2004 | 09:46 PM
Gord's Avatar
Wow, I really like that, kind of old-camaroish, like early 80s, im sure someones already mentioned that but Im too lazy to read them all, also has kind of a monte carlo rear
Old Apr 6, 2004 | 06:57 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Nice job. I agree with the smoked or neutral density lens for the third brake light. Maybe similar to what Pontiac did with the T/A taillights. And it does have a slight retro touch similar to the early '70s Z-28s with the larger spoiler.
Old Apr 6, 2004 | 07:58 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I commented on a spoiler more like the Lamborghini's although straight across but lifted from the surface...in regard to the other spoiler thread. I know Camaro's and Firebirds differ, but there are those ones that run along the base of the trunk for both cars. My question is is there a specific different name? Often I might say air-foil, but it just doesn't sound right. I'd refer to the front versions as 'air dams', What's the correct terms I should be using??
As far as the Cadillac style brake light, I've always felt they hit on the idea that should have been employed from the inception...it's classy and does it's intent w/o being obvious from the cabin, and taking up space.
I've owned a Cadillac, and own one now as well, so I think it's a novel approach. Me likes
-B
Old Apr 8, 2004 | 06:51 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Honestly Willie, it looks good!! I almost want to take off my 91z spoiler and put that one on.
Old Apr 8, 2004 | 08:11 AM
PontiacRacing's Avatar
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
Not sure if I would put it on my Camaro, but it looks good on your car.
Old Apr 8, 2004 | 08:56 AM
Cargasm's Avatar
I think it looks amazing... especially with the LED bar and new striping. Well done!! :hail:
Old Apr 9, 2004 | 04:29 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Looks excellent willie! I personally, like the oem brake light with LED's in it, but yours still looks great.
I still haven't received mine yet.
Old Apr 10, 2004 | 05:02 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
looks awesome man! I think if you put a 91-92 bumper on there it would look even better. The little flare part would compliment the spoiler. good job on the install
Old Apr 11, 2004 | 06:33 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
I have one of those on my 83 Z28, I'm a big fan of that spoiler, the stocker looks too small and most of the rest appear to make a great handle for something. That spoiler reminds me of the mid 80 trans-am cars. Nice job on the install.
Old Apr 12, 2004 | 01:54 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Willie,
I like the spoiler, I actually have one myself and my car is also white. I couldn't agree with you more on the rear look, it just doesn't seem to blend in that well (nice job with the tape btw). I also think that the left and right sections might be a little too much! I was thinking of shortening both side and center sections a little before I have the car painted. I am just not 100% happy with the way it looks. I do however think that Bruce did a fabulous job designing it! I just need to tailor it to my liking.
BTW, where did you get the light bar? I was thinking of doing something similar to that.
Old Apr 12, 2004 | 02:12 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well willie firs toff i gotta say wicked job, personally i don't like the 5 inch spoiler but great job none the less
Old Apr 12, 2004 | 06:18 PM
85_ZED28's Avatar
Car: '85 Z28
beat me to it! exactly what i was thinking
Old Apr 12, 2004 | 06:22 PM
Car: 91 Camaro RS
Engine: TBI
So who else has theres already? I got mine today. Emailed him the other day casue it had yet to bill and was supposed to be billed and shipped on april 19th. They said they had shipped it on the 6th and it showed up this afternoon. Test fitted it and fit good. Had to slightly ream the two holes on the far left of the deck but we're talking minor. Had some teal paint but when i saw the massiveness of the wing i decided i dint have enough and didnt have enough to go buy another can so i rattle canned it gloss black for now the cars getting paint this summer so i'll do the full prep work then. I like how it looks though and that was primed. TOmmorrow mornign i'll put it on and get some good pics to post.
Old May 6, 2004 | 10:49 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
I have yet to do mine...many other projects going on with the same car. I have swapped my 91 Aerowing hatch and sold it. My car is not drilled on the end caps (quarter panels). Anyone have a suggetion on how to do this and get it as close to right the first time? Measurements...anything of the sort? I have the 91 rear valence so hopefully that will balance the massiveness of the spoiler from the rear. After all 91-92 cars are all flaired out anyways...it just might look "right".
Nice job willie. The spoiler looks great on your car IMO. The tape trick is kinda neat. If I don't like mine i may borrow your trick (if it's ok), and I should be able to pull it off with the blackouts on the back. I figure my car will prolly look like the white one on Hawks website. And BTW...thanks for getting the g.p. to happen. I am more than pleased with the spoiler. I commend Bruce on a great product, and for the free t-shirt too.
Old May 6, 2004 | 11:59 PM
chevyrumble83's Avatar
Car: 1983 Z28
WOW thats a bit to much, i think the highrise spoiler looks alot better. i luv the brake light though do they make stock size ones with the brake like in it? so u can just buy the middle part of the spoiler?
Old May 7, 2004 | 03:25 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Looks great! Wish I could afford to do things like that... but then again, your car deserves it! Gotta be my fav 3rd gen... not sucking up or anything either!
Old May 13, 2004 | 03:40 PM
bluehog67's Avatar
Car: RS
The 5 inch Spoiler ROCKS!!!
Old May 14, 2004 | 01:36 AM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
First of all, I'm amazed by the polarity of responses to this spoiler, folks either love it or hate it..... very few middle of the road comments, lol! Personally, I love it! Definately on my list of mods, for sure! I'm a huge NASCAR fan, and when I first saw this unit, I thought "Cool! NASCAR! Gotta have it!!" It definately makes your car look a bit wider, I think because it adds an illusion of width up high that the stock spoiler lacks. I also agree that the color of your car makes it stand out a bit more than it would on say, a black, blue or red Camaro. The tape mod is slick, makes the dark area between the lights look a bit more massive, aggressive. Very well done! :hail:
One question, is there enough space inside the spoiler to possibly fab in the stock third brake light? It looks to be a bit thinner front to back than the stock unit.
Linson
Oct 24, 2025 02:00 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
jaridjohn
Oct 5, 2015 07:01 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
efiguy
Sep 27, 2015 01:30 PM
