T Top Flew away
Old Apr 7, 2004 | 06:18 PM
IroczCamar0's Avatar
Car: 1989 Pontiac Trans AM GTA
T Top Flew away
I dont know if anyone has experienced this but i am drivin along and my T-top starts shaking than flys off, i stop and hope its still intact but all the glass is gone.I must have not latched it all the way . I put some clear plastic, duct tape and the t-top minus the glass or whats left of the t-top, ill try to post a pic soon .It will protect against the rain it for now it looks like but i am wondering if all the t-tops are interchangable or is my 85 iroc only compatible with 85 camaro ttops casuse i need one real bad and dont know if other years will fit.
Old Apr 7, 2004 | 06:35 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
There all the same, no matter what year
Old Apr 7, 2004 | 06:54 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
they may look the same, but the latching system is different on the newer thirdgens, the older ones use "J" hook type, where as the newer ones use pin style
Old Apr 7, 2004 | 06:59 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
I have 2 85 T/A's with T-Tops, one has a metal frame around the glass, the other does not.
yea ill take a trip to the junk yard and pick one up thanks
Old Apr 7, 2004 | 07:50 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Judging from the few sets that I have, it seems like the locking t-tops had no metal trim and also have the entire perimeter darkened. The non-lockers have metal trim and only the outside edge darkened. Is this the case for yours too?
in any case, for compatibility you just want to look at your latching mechanism. It'll be either hooks, small pins or big pins. Also the big pins can have the plastic piece removed and there's a small pin underneath so they're somewhat interchangable too
Old Apr 8, 2004 | 04:28 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
What do you mean by "J" hook and pin type...I have an 82 and its jus two rods going into a hole on both sides...don't know about the "j" It happened to me...my brother didn't latch my t-top on right and on the freeway it just flew off...luckily it was late at night and no one was behind me and it landed off to the side. I just went to the yard and picked up one for $40.
Old Apr 8, 2004 | 09:42 AM
CaysE's Avatar
There are also the "Cars and Concepts" t-tops that were put on some third-gens. So basically there are three different types.
Old Apr 8, 2004 | 09:55 AM
MNformula350's Avatar
my 84 non locking t-tops were like that (i still have them) and the 2 cars i have/had with locking t's dont (83 T/A-gone- my 87 Iroc and my 90 Formula)
Old Apr 8, 2004 | 10:44 AM
Faded's Avatar
Car: '91 Firebird
85 Camaro t-tops would not fit properly on my 91 Bird. They had the same latching system, they just had a different contour to them...
Old Apr 8, 2004 | 01:05 PM
SC82TA's Avatar
That last post reminds me of something. The t-top I bought would not latch on...I had to adjust the brackets that they lock on to. Under the plastic trim pieces there are two metal brackets that have two screws that can be shifted up and down a little bit. The pin was hitting them so I had to slide them so the pin would clear and the top would latch. Just thought you should know so you don't freak out if the t-tops were to not latch on from the get go....you do have some adjustment to work with.
Old Apr 8, 2004 | 01:14 PM
Faded's Avatar
Car: '91 Firebird
Hmm... I still have these tops stowed away in my basement somewhere. I'll have to dig them out and see if that's the case. Thanks man.
Old Apr 8, 2004 | 01:38 PM
CaysE's Avatar
Those brackets are hard plastic, by the way; they will crack if you overtighten the screws. At least, that's how it is on my car.
Old Apr 8, 2004 | 01:46 PM
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
i jsut came across 2 sets of 3rd gen t-tops in the junk yard yesterday, completely intact, they were both solid glass with a door hand type release handle on them, where ive seen others with a frame around them and plastic releast type handles.
the junkyard is MIDWESTERN AUTO PARTS in elgin,illinois, i know they do ship.
Old Apr 8, 2004 | 02:10 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
82 & 83 have the same t-tops then they changed it & the 84s on work.
I had a guy that bought a set of 84 ttops for his 83 camaro changed out the stuff thats on the car & they fit tighter & alot nicer then the org ones.
Old Apr 8, 2004 | 03:15 PM
SC82TA's Avatar
Nope mine certainly were metal not plastic...in fact one of the pins still hit slightly even after I adjusted it that I took a file and filed it a bit so it would clear better. I think the replacement t-top that I bought came from either an 85 or an 86.
Old Apr 8, 2004 | 05:02 PM
CaysE's Avatar
I guess the 82-83 cars had a metal bracket there? I'd like to find something stronger than the plastic crap I have.
Old Apr 8, 2004 | 08:58 PM
maverick351ci's Avatar
Car: 1985 Firebird
wow that happend to me like 4 months ago im driving i hear a wind noise il like wtf and then wooooooooooosh there goes the pass t-top and i start freezing since it was 12 degrees outside but i got lucky it happend at night going down the interstate i looked for it for 3 days adn finally found it all in one peice without a scratch on it and it left the car when i was doing 80 or better
Old Apr 9, 2004 | 09:45 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
The same thing happened to me last year on the way to a car show and it then started raining it did not last long and I made it home without it raining anymore.
Old Apr 9, 2004 | 11:02 AM
Paipe90GTA's Avatar
Car: 90' TA GTA
I had my hood fly off about 2 months ago, i would have had one of my t-tops fly rather then my hood. ( i know its not what you were discussing but its similar, i dont mean to hi-jack your thread)
Old Apr 9, 2004 | 02:57 PM
Faded's Avatar
Car: '91 Firebird
One day I unlatched my drivers side t-top, and then ym phone starts ringing. So I have a 15 minute conversation, and completely forget about the T-tops. I drive off, and I'm going 45 down a road, and suddenly my T-top flies off. Thing is though, I CAUGHT IT. It went off to the side, so I managed to get it with my left hand. Damn near almost swerved off the road though.
Old Apr 9, 2004 | 05:19 PM
CaysE's Avatar
Yeah, that would suck if you saved the t-top and totalled the car.
Old Apr 9, 2004 | 06:29 PM
yea i found a ttop on ebay but the auction wont end for a couple of days and it will take time to have it shipped and its supposed to rain here from sun to tues. Well then i decided i could borrow my friends ttop until mine gets here, hes got an 86 iroc and its in his garage and hes not puttin it on the road til may .his ttop fits great on my car so i have 2 ttops for now.
Old Apr 9, 2004 | 09:36 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Yep. I lost my 82 T-top in a similar situation. I picked up a spare one from 82-83, but got a spare locking set from an 88 along with the latching hardware (pins) and yes, the 82-83 hooks go into a metal bracket, and the later year pins go into a plastic bracket.
Ditto on the metal trim around them. I'm not sure on the shading, but my 82-83 tops have the trim, and the 88 tops I found have no trim.
Old Apr 10, 2004 | 09:57 PM
85 T/A WS6's Avatar
Both sets are locking
Old Jul 27, 2004 | 08:12 PM
CaysE's Avatar
Originally posted by kanuck
...I picked up a spare one from 82-83, but got a spare locking set from an 88 along with the latching hardware (pins) and yes, the 82-83 hooks go into a metal bracket, and the later year pins go into a plastic bracket...
Does anyone know if the metal brackets have a different part number than the plastic ones?
Old Jul 28, 2004 | 12:43 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I know you can put 85 86 87 Glass T tops onto the later 90-92s because the pin style is the same idea, but a smaller pin on the tops itself. The holes on the chassis from the 90-92 are bigger (they were lexan tops) so I dont think you could pull later 90-92 tops. At least this is my experience w/ the ex g/f's 92 and some 86 T tops...
Old Jul 28, 2004 | 06:59 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
take a trip to the bone yard and pray theres one like yours. Or check ebay?
Nate
Old Jul 28, 2004 | 08:41 AM
CaysE's Avatar
I'm sure he has t-tops by now, this thread is from April. I'm asking if there is a part number for the metal bracket that the pin goes into.
Old Jul 28, 2004 | 11:02 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
My 1986 has plastic trim around the pin holders, but I've pulled the trim off and the pin holders themselves are metal and secured with two screws.
My car, btw, has locking T-tops with pins and no metal frame.
Old Jul 29, 2004 | 10:25 AM
CaysE's Avatar
Are you positive they're metal? I'm 98% sure mine are plastic, and I have an 86 as well.
Old Jul 29, 2004 | 12:58 PM
RSFreak's Avatar
Transmission: TH700R4
My '84 and '91 tops are totally interchangable.
Old Jul 29, 2004 | 08:35 PM
Crayz9000's Avatar
Engine: LB9 5.0L
I'll have a look when I work on the car tonight. I'm just waiting for it to cool down outside first.
Edit: Ok, now I looked. Yeah, sorry, they're plastic -- I just thought for some reason they were metal. Guess I should keep a close eye on them for cracks; I don't want mine flying off...
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rsrookie
Sep 5, 2015 07:08 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
