custom intake pics
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
custom intake pics
Thought I'd pop in breifly to say hi and show how the plenums going. Had to fix a little vacuum leak so I gave it a test fit while I had the top off. Been waiting for a reason to pull her apart for the test fit and to line up the linkage, etc.
Dean
Dean
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Guess there isnt life after TGO.
Car: '87 Cam RS V6
Engine: Top Secret
Tom, I made the alt bracket out of some 3/16"stock, just cut it out, rounded the edges and polished it. That's a V8 TPI 140amp alt on there so I needed a custom bracket support.
The plenum is NOT finished- just a test fit while I was working on some vacuum lines. I had to mark where the linkage bracket screws to it so I can fab that up. Top is still not attached either, but I did temporarly seal it and fired the motor with it on- it idled stable.
Here's a shot of the stock plenum and TB sitting on top for comparison.
This project is just a backburner toy when I have time. The Cooper is taking priority - this is my first day off work in 4 1/2 weeks (even Sundays). http://www.cardomain.com/memberpage/518752/3
I'm very busy with work and the house remodel, then the Cooper, and lastly the Camaro- I am actually redoing a new air bag setup on my work truck next Thurs-Sat to freshen it up have to pull the bed off for the install.
Looks mean. Real mean. Can't beat custom. Ebert & Roeper say:
Car: '87 Cam RS V6
Engine: Top Secret
Re: One more thing:
Originally posted by FbodTrek
Where did the Throttle Body come from?
The whole idea of this intake design is to free up the restriction on the intake side of the engine. We suffer greatly from the tight 60* cylinder banks when related to intake flow. This is why these motors "respond to boost" so well. Boost forces the mixture through the tight restrictive narrow snaking bends. Anytime either liquid or air is drawn through a bend more than 45*, flow is greatly decreased, even under boost. Fact is- two 45* bends are much better than one 90* bend.
With that said, we have an uncorrectable aprox 120* bend into the camber from which draws the air into the port to feed itself. By increasing plenum volume, AND decreasing runner length will feed the head intake port mcuh better causing less cavitation at higher rpm's. (and lower rpm's when motor is built also. This calls for much higher flow demand at lower rpm's also) Runner velocity doesn't mean squat when its starving by sucking through a long straw with lots of bends.
Car: '87 Cam RS V6
Engine: Top Secret
Link in the "read me first" for the 62mm TB- they are now $340 ouch. http://www.jbodyperformance.com/fdptb.html
Edit: I take that back- $340 Canadian/ $242 US
Car: 89 f-bird and some others
Engine: 3.4
Looks pretty good. Once i get a 3.4 in i'm thinking about using the 2.8 to fab my own dual tb intake. Then i'll bolt it onto the 3.4 see how it does.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Hey how much for an alt bracket liek that i need a 140 amp alternator on my car too. I used to have one but it died and i cant afford to fork out 400.00 for a new 160 amp one. What size motor you have BTW
Car: 1984 F41 T-Top
Transmission: 5 speed
Go down to the Home Depot, Lowes', metal speciality shop, or supply store. They are straight pieces of aluminum (or steel) that range in thickness, length, and width. The price also ranges from a few bucks to around $40 and a little up depending on the type of store.
I found that Home Depot and Lowes' tend to have them in the roofing, screw/nail, or close to the wood section, but will very from store to store so look closely.
Aluminum is easy to craft, just make a design and mark it to the aluminum. If you don't have a bandsaw you can use a jigsaw to cut out big pieces, but predrilled holes along the outside line will help you cut more better and quicker. Then you can sand the rest down with a belt sander (or grinder) to remove the big bumps/ sharp edges and finalize it with a palm or hand sanding.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Nice work.
But I'm admiring the alt. work. You just gave me an idea on how to solve one of my problems
Thanks!!
Thanks!! Thread Starter
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by MrDude_1
looks good....
slightly off subject.
whats the plans for the minicooper?
looks good....
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
cool.
when i was 12 my dad got a right hand drive minicooper...
should make for a killer autoX machine... they dont weigh jack.
Car: '87 Cam RS V6
Engine: Top Secret
No autoX, I am building it for roadracing (HSR West, VARA-not for points just fun they frown on modification but do have a few full modded minis running for fun out of class.) There are 4 (2 and 3 day) events just local per years at California Speedway.
Back to subject-
Everyone seem to like the alt bracket- Like the guy stated a few post above, They are very simple to from out of aluminium. I run a crank power pulley and have had problems in the past with idle discharge especially with the lights on at night dimming at idle. It will radically discharge with the a/c on at lights to a point where it will cause the motor to stumble at idle. The 140amp V8 alt cured that. I tried a 200amp Powermaster on it a few years back, but that had too large of a housing and rubbed the STB, and also drained back what power I gained from the smaller crank pulley(too heavy of a magnetic feild under charge)
I have a top secret alt setup I am working on with the Mini- self generating power.
Back to subject-
Car: '87 Cam RS V6
Engine: Top Secret
Here's a better shot of the alt bracket. Look close in the picture and you will see one of my custom lower frame braces also. This boxes the steeringbox in the rear also (GW wonderbar in front). This is something we can do that the V8 cars can't.
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
. Great work on that plenum! Get any kind of noticable gain from it? Haha, funny I remember you brainstorming this on fathers day, the finished product is just great
Car: 85 firebird
Yeah even though we've had problems you do know alot about suspension work, you just have a VERY short temper!
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
my question is, why would GM make the manifold they came up with for these engines if just an empty aluminum box would work better and be much cheaper to do? im not trying to be a smart ***, just want to know why this is better and why its not like this stock if its so simple. emissions? noise?
Car: 85 firebird
Why did GM do anything, if you start counting the "whys" on your fingers you'll run out of fingers real fast!
Car: '87 Cam RS V6
Engine: Top Secret
My design is not intended to be bolted to a stock motor/ hence why I keep saying it will not go onto this motor. The motor it will feed will produce aprox 240hp naturally asperated and exceed 8000rpms- not a stock 140hp motor or even my slightly modified 2.8. I explained this a few posts above already.
Pasky and Brobert, thankyou for the compliments- I will try to behave. Although I don't think EDE will keep me around long enough to worry about it.
Edit: EDE banned my cousin Derek thinking it was me (Halfpint) He's pissed.
Ah ok, wasn't sure what he was putting it on. Yea i know coopers are british, but I thought he was throwing the intake in his camaro on top of a japanese engine he was gonna swap in.
Engine: 350 S-TPI
His plans are to drop a 3.5l RWD block with oversized valves, massive port job, roller rockers, custom springs/retainers, and some expensive lower end block work. Then that intake, and another middle section he has ported. This is all after his 2.8 wears out (many years, its new).
The mini copper I'm sure will be just as crazy. The old minis are british, but the new ones are made by BMW, which is German.
Car: 91 Camaro
he is putting that intake on his camaro and last i heard, the new engine will be a 3.4. am i right, dean?
Car: '87 Cam RS V6
Engine: Top Secret
https://www.thirdgen.org/techbb2/sho...ht=%2Asheet%2A
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by AM91Camaro_RS
a 3.5? is that a 3.4 punched to +.030" or +.040" or what?
3.4 = 3.62"bore
3.5= 3.66"bore (+.040 over)
Technically I would be about a 3.475L @ +.030 over- close enough. It will be whatever it takes to clean up the used block I eventually find- But I definately want a used hardened block to machine, not new. For those that are wondering why? Used blocks have been heat cycled and are hardened already with age.
Car: '87 Cam RS V6
Engine: Top Secret
Re: Your
You're building it to rev to 8 grand? That is going to be awesome.
Now before I happen to offend someone because I stated "It has never been done", let me explain-
Noone has built a hotrod 60*V6 for ground up that I have every seen with top dollar internals- only GM factory race motors, and even then it was years back with older technology.
I judge a major custom carshow here in So. Cal (Thunderfest) for 6 years and have seen just about everything (For the record- major means Dave "The Voice" McCleland announces it every year in person)- Never seen a truely built 60*V6 RWD I intend to do that and show this car in another 10 years when they really begin to become classic- I'll have something that noone has ever seen AND can probably not duplicate because of the rarity of parts that I have made and acquired. This car corners like no V8 car can- I've driven many, I know. Thats why I built this V6 car because it corners like its "ON A RAIL"
Ps- I love using up bandwith
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
As asked before, how does your design differ from the stock design? The only way I see getting rid of the tight bends of the stock intake would be to raise the upper plenum giving you the room to turn that 90* (I thought it was 135*) into two 45* bends. That intake appears to sit at the same height as the stock one so how did you accomplish your goal of dividing the angle into two smaller ones without using more length. Plus, increasing the runner length will add to hp and torque. I am the person who modified the TPI intake to fit my 3.4L. I don't care for the tight bends involved but I just needed to fab something for it fast to get the motor running. I am working on another one now where I use two lower plenum sections to help cut down on the restriction seeing how most of the restriction in the intake is in the upper plenum. Here's the link to my site:
http://www.angelfire.com/crazy3/jimsfirebird/
Just click on the button that says '3.4L intake'. And please forgive all of the crazy insert ads.
Jim
Jim
Car: '87 Cam RS V6
Engine: Top Secret
Jeriko, Heres a camparision shot of the internal of a Holley Stealth Ram/ and my design- same basic premise. You have a larger volume plenum to feed from and shorter runners for a more direct straight shot and higher rpms. Longer runners add HP down low. The roof of my unit is taller than the stock unit and much more open to feed the ports.
my 90* example was just that- an example that 2-45*s flow better than 1-90* bend. I do realise that the stock upper to lower bend is aprox 135*, But thank you. I feed directly into the port with a mere 45* bend from the plenum chamber through much larger port openings.
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by CaliCamaroRS
You still want my block?
Otherwises, no thankyou I will worry about finding one when the time comes.
Car: 91 Camaro Vert
thats a lingenfelter super ram, not a Holley Stealth Ram.
while your design is a big improvement, i still think a new lower intake would be needed to fully optimize the motor.. notice the SR uses a diffrent lower base....
Engine: 3.4L 207 V6
Also, just because you have opened up the upper plenum the air still has to bend 90* before it goes to the 45* bend of the lower plenum. The air doesn't simple appear at the TB and magically shoot down the lower intake. It still has to go through the TB bend towards the appropriate runner and then bend 90* downward and then other *45.
But still, I like the idea. I just think that it needs to sit at least two inches higher.
Another question, is that box welded onto the lower plenum?
Car: '87 Cam RS V6
Engine: Top Secret
You guys need to re-look at the middle and lower intake manifolds bolted together. You can't get a strighter passage to the head than the stock design, and mine has been opened alot more. So you are saying I should put some bends into it?
As for the air still having to bend 90* into the port (then the 45*), thats the whole point of larger volume plenums- your not getting it. I have alot more open volume to feed each port as it is demanded-
rather than funneling throiugh the longer runner to the smaller chamber stock plenum. This also has both 90* into runners AND 90* into the 45* minddle.
Air intake is not a constant flow into each port- the air pulses/ there is however constant air flow into the TB filling the larger plenum area to feed each pulse and reduce scavange- hence the larger TB also.
* Please note that I am respectfully and contructively debating- Thanks guys*
Engine: 3.4L 207 V6
Creative discussion is awesome.
I must have missed the part about suggesting more bends with the intake. I don't agree with that.
That larger volume of air does you no good since it still has to fit through the lower plenum. That is your bottle neck. To get the idea to work great, you would have to port out the heads, intake and plenums. Increasing only a portion of the intake does you no good. I know you plan on during this later on but you have said nothing about changing the lower plenum. If I go buy a large and small drink from McDonald's, I can't drink the larger drink faster simply because there is more volume if the straws are the same size. Increase the straw and increase the total flow. I understand that you have increased the potential volume but doesn't do you any good if ALL parts of the intake are increased.
Jim
Jim
Good example, but I still think he will gain a bit even without modifying the lower plenum, although he will see a much better gain if he does. By doing what he has done, he still knocked off a restriction the upper plenum has which is those long skinny runners. The air can get directly down to those lower plenum ports and maximize the space they currently have which I don't believe the upper plenum did. But yes, much is to gain by changing or porting the lower plenum.
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
His design is sound
What he's doing is getting rid of the restriction that the tight bend causes to flow dynamics. He has, in effect, pushed his powerband higher in the RPM band. By using the larger plenum volume, he is able to successfully feed the motor at the higher rpms (which is what the motor is designed to make power at). He has no reason to lengthen the runners, he's going to be pushing to 8 grand. That bend is a huge restriction in itself on these motors, but that was the only way GM could make the torque curve low enough for what they wanted, and still fit under the hood. I firmly belive that lessening (if that's a word..) the curve would net a decent gain. I'll be doing some tweaking on the dyno with variable runner lengths soon, I'll post the graphs.
im really interested in the power gains from that!
