fender again.....
Old Jun 17, 2004 | 12:11 PM
89caliMaro's Avatar
Car: 1989 Camaro Rs
Engine: 5.0 TBI
fender again.....
ok ill try to explain this my passenger fender is out of alignment....more than likely it is the frame but i was wondering if i could fix the fender without having to get the frame pulled.when i try to open the door it hits the fender because the fender almost goes underneath the dooor....At the top it is almost under the door but as you go down the gap between the fender and the door widens to id say 1/2" to 3/4" and the top of the hood closest to the fender sticks up a bit and there is also a gap between the fender and the hood....about the same as the door and the fender.. any suggestions? if any way possible please help me out..
Old Jun 17, 2004 | 12:23 PM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
Have you tried playing with the adjustment of the fender? If you loosen up the bolts the fender alignment has some play in it. You might be able to loosen up the bottom two bolts and pull the bottom of the fender forward.
Old Jun 17, 2004 | 07:50 PM
89caliMaro's Avatar
Car: 1989 Camaro Rs
Engine: 5.0 TBI
i checked the adjustment and its adjusted all the way out that it can be....
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
