Underhood sticker specs
Old Jul 5, 2004 | 01:52 AM
joshwilson3's Avatar
Old Jul 5, 2004 | 02:24 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
90+ had the base time at 0 deg while the previous years called for 6 deg BDTC. Have you done any ignition work? The popping and fluctuating rpms sound like possible misfiring.
Old Jul 5, 2004 | 04:28 AM
Old Jul 5, 2004 | 08:43 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Sounds like maybe the shop didn't disconnect the timing control on the firewall wire harness. If they didn't your initial timing is probably at 28* retarded even though it's reading 6*. Not only does this kill power, the gas mileage will be cut in half. The instruction's are also on the under hood sticker wich your missing!
In 1989 the initial timing went from 0* to 6* on the 305 TBI and plug gap is .35 plug's are AC-R45TS.
It is possible the shop screwed up because my son took my bird
to 2 differnt shops to get it tuned up and both of them set the timing without disconnecting the control link. Even though it ran, it ran like crap and the mileage sucked. So he sold it to me cheap.
On the first day I had it I figured out what they did wrong and had it running like a watch! I offerd to sell it back but he already
had bought a truck.
Old Jul 5, 2004 | 11:45 AM
Old Jul 5, 2004 | 11:56 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Do you know where the connector is? I would check it! Maybe they forgot to hook it back up!
slow91camaro's Avatar
Car: '91 Camaro Z-28
Transmission: auto
I think SQZBOX nailed it dead on. My buddy recently picked up a tbi car with the same exact problems. That popping your hearing is probably unburned fuel igniting in the cat, at least that's what was happening in my buddy's car.
Once we disconnected the timing control wire and put the timing light we found it was significantly retarded. Once we set the timing where it needed to be the idle smoothed out and the power nearly doubled.
Before we fixed the timing we were also getting the ESC code. But for the most part that went alway also. We figured the ESC code was from a cylinder loading up, misfiring and being read as knock.
Old Jul 5, 2004 | 04:56 PM
Old Jul 5, 2004 | 05:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Here is the wire that needs to be unplugged for the timing.
Old Jul 5, 2004 | 05:59 PM
Old Jul 5, 2004 | 08:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by joshwilson3
Thanks for your help. I really appreciate the time you took. I'll check that as soon as it quits raining.
Alright, it is connected. So that's not the problem. Since the timing is right and it runs, I'll just ignore it. Do you think it will do any harm having the poping? It has died on me twice when I was at a stop. But the mechanic said that it wasn't knocking, but was compression, and would be fine. So I guess I just won't worry about it.
Well I geuss I should have added that even if it is connected it may not be set right. It needs to be dissconnected, have the base timing set, and then reconnected.
Old Jul 5, 2004 | 10:01 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Have you checked the base time? With the connector disconnected, anywhere from 6-8 degrees BTDC is fine. If that looks ok then check the rest of the ignition system for loose or burnt wires or any other sort of problem.
Old Jul 5, 2004 | 10:34 PM
Old Jul 5, 2004 | 10:42 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Dont let it go on. There is obviously something wrong. Does the motor lack pickup when you hit the gas or is it just uneaven and rough? Both misfires and retarded timing will cause some popping through an exaust. The retarded timing makes teh motor sound real sick, though, and it doesnt have any pickup. The missing will cause some power loss but most importantly the arcing can damage things and will cause the motor to run rough and idle erratically if its only intermittently firing the cylinder(s) in question.
Old Jul 6, 2004 | 01:08 AM
Transmission: auto
A good shop should have set your timing with that wire disconnected, but that doesn't mean they did. I went to a highly recommended shop(a few years ago) to handle a distributor problem on my car and when I got it back it was running really bad. I took it back, they got out the timing light and showed me it was set correctly. I pointed out that they didn't disconnect the wire and when they did the timing light showed the timing was retarded about 20 degrees.
Take it back, it only takes them a few minutes to adjust the timing, if they don't disconnect that wire, do it for them.
Again, your problems mirror those on my friend's car. Someone had obviously tried to set the timing on his car without disconnecting the wire in question. Once we set it correctly the problems disappeared.
Old Jul 6, 2004 | 02:23 AM
Old Jul 7, 2004 | 01:47 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Just for future reference here are the underhood sticker shots.
Old Jul 7, 2004 | 01:48 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
And vacuum.
Old Jul 7, 2004 | 03:15 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Yeah, I'll have them check the timing again, and I'll be back there to make sure they do it right. Unplug brown/black wire, check timing and set, then hook wire back up. I'll go out tonite and see if I see any arcing cause maybe the new wires were bad??
Exacly how the car sounds will tell alot. Through the stock exaust too little timing will sort of sound like a continuous popping sound with a motor that jsut generally runs like crap since the mixture is still burning when the exaust valve opens rather then be fully burned on the downstroke of the piston. This will also cause the exaust to get so hot that it glows, which in turn will trash all the stuff near the exaust thats not made of metal.
The intermittent miss will cause a spitting noise out the exaust with fluctuating rpms. It could be a plug boot thats not on all the way or a damaged spark plug. Id take it to a reputable shop or a dealer thats known for good service if the present shop can't fix it right for free on your next trip in.
Twin_Turbo
Mar 14, 2016 10:10 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
