SLP Loudmouth System Pictures............
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Hey Flynlow Do you bang you're exhaust alot? I had mine installed by Mufflex about a month ago and it bangs on my driveway all the time.. I didn't think ground clearance was gonna be so bad.. I took the car in to get diagnostics run on the dyno at a shop beacuse I failed emissions and they couldnt get the car on the dyno beacuse of the exhaust being so low
I do have the eibach pro kit, the exhaust sits only a few inches from the ground..
http://24.228.48.140:300/images/my91z28/lm1.jpg
I do have the eibach pro kit, the exhaust sits only a few inches from the ground.. http://24.228.48.140:300/images/my91z28/lm1.jpg
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
i realy would like to have the lm for my car and i only have a 305 tbi but i am planning for an ls1. now i want to know everything. how much did it cost? does it attach to cat? or what do you have to do to make it work with my 305. and if you could list the part numbers.
My y-pipe takes most of the beating since it's lower then the actual exhaust....
88SS6SPEED
Nov 11, 2015 07:05 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
