Ported L98 Iron Heads
Old Oct 1, 2004 | 11:58 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i had a friend of mine port my heads for me, and i just had them flow benched. im kinda upset at the results and i'd like to know what to do to make the exhaust flow a little bit more. if anyone has any suggestions, please let me know what you think i should do to get these heads flowing better. valves are 1.94 / 1.5 w/ a 3 angle valve job. i don't want to put a lot of money into these heads so i'd probably end up porting these heads myself. like i said, any suggestions on how to get the exhaust cfm's up would be greatly appriciated i'm just wondering how my intake seems to be flowing better but my exhaust doesn't. thanks in advance
lift intake exhaust
050 30.5 cfm 22.3 cfm
100 62.0 cfm 45.8 cfm
150 95.0 cfm 67.0 cfm
200 126.0 cfm 87.5 cfm
250 154.0 cfm 102.0 cfm
300 173.0 cfm 112.0 cfm
350 190.0 cfm 120.0 cfm
400 204.0 cfm 127.0 cfm
450 208.5 cfm 133.0 cfm
500 207.0 cfm 137.0 cfm
Old Oct 2, 2004 | 12:36 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
1083's
That's because those heads are not worth screwing with, regardless what anybody tells you. They are old school technology. Put your time and $$$ into something worth while.
Old Oct 2, 2004 | 12:51 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Re: 1083's
Not so. You just have to spend some time with them. Without seeing what has already been done I can't offer any advise but you can look over the thread linked at the end of my sig for some help.
Old Oct 2, 2004 | 04:28 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Actually the intake side on your heads kinda sucks too.
You should be a right around 225-235 for a home ported head with 160-180 on the exhaust side. (1.94-1.50 valves)
Was the head flowed with a inlet radius plate and exhaust tube during testing? makes a difference.
Like SB said hard to tell ya more without seeing whats done to the ports.
many people had gotten good results with these heads.
Old Oct 2, 2004 | 10:35 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
at the bottom of my flow chart, it says "radius inlet" and some markings i can't understand, and then it also says "open no pipe"...
i think im just going to go out and get some better heads for later down the line in a few months
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
beastin91rs
Oct 9, 2015 07:38 AM
