View Poll Results: Run wheel spacers?
Yes gotta love 4th gen rims
63.64%
No youl kill yourself and your car
36.36%
Voters: 11. You may not vote on this poll
Weel spacers ok or not?
Old Nov 3, 2004 | 08:11 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
im looking into my options for rims and im really likein the 18x11 zo6 rism but have heard soem horror stories of wheel spacers how many of u have run em withouta problem and what precautions can u take to better u chances?
Old Nov 3, 2004 | 09:17 PM
_max_'s Avatar
got 2000 SS ZR1 wheels on my car front spacers only put a 4thgen rear in my car no problems with spacers 2" tires rub a little you might have trouble with 11" wheels though
Old Nov 8, 2004 | 10:06 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I've sold many (hundreds of pairs) of the billet wheel adapters, and have not had any failures, so the horror stories may have been from improperly machined adapters, bad installation, etc. If there have been horror stories, I haven't seen them here. It's usually a friend of the counter guy's at the AutoZone that had a girlfriends brother try to mount Ferrari wheels on his Escort or something...The one problem we did have a few years ago was where a person did not measure their car properly, and ordered the wrong (custom) adapters.
The right precautions are to make sure the mounting surface and studs are clean, use anti-seize on the studs for an accurate torque reading, and torque the adapters and rims using a star pattern, starting at a low torque (hand tight), maybe again at 50 ft-lbs, then to final torque (usually 85 ft-lbs). When the adapters have not been used (brand new, fresh out of the CNC), I also suggest taking a 5 mile drive, and re-torquing them to the hub.
Andris Skulte, w/ 17x11 ZR1's in the rear
www.skulte.com
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
