How does this setup look.....
Old Nov 23, 2004 | 09:34 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Like the title says, I am interested to see what you guys think about this setup. I have done the searches which is how I decided on a couple of the components.
Here is what I am thinking:
First off, I am using my 350 TPI motor as the starting point.
Holley Stealth Ram
AFR 190 Heads, 68cc chambers
Comp Cams XR288HR cam
Specs @.050: 236/242, .520/.540, 110
1.6 Roller Rockers
TCI SSF 3500rpm converter
Probuilt 700R4 Street/Strip Tranny
Any input on this setup is appreciated.
Also, the only thing I haven't decided on is what rear gear ratio to go with. Any and all suggestions welcome on this as well.
I should mention that this is not my daily driver but will be driven on the streets and will remain mostly street but will see plenty of strip time throughout the year.
TIA
John
Old Nov 23, 2004 | 09:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
I don't know about that cam, you might want to run a computer grind, so your computer doesn't have major fits.
Old Nov 23, 2004 | 10:14 PM
White91GTA's Avatar
Engine: 5.7L TPI
ME Leigh...I will be taking the car to Ed Wright for tuning. What grind would you recommend though? I am open to any and all suggestions.
Old Nov 23, 2004 | 10:27 PM
ME Leigh's Avatar
Car: 82 Z28
With a computer a cam with a wider LSA is required, for several reasons. The narrowest you could get away with it probably 110 LSA., with major tuning hassels.
I'd recommend the 08-503-8 XR276HR or the 08-305-8 274HR-14 those are biggest computer cams available.
I'm no expert you might just want to ask ask your tuner what he would recommend.
Old Nov 25, 2004 | 08:48 PM
White91GTA's Avatar
Engine: 5.7L TPI
TTT...anyone else have any input on this setup?
Old Nov 26, 2004 | 06:54 PM
White91GTA's Avatar
Engine: 5.7L TPI
Ran this setup on DD2000 and it is showing:
Max HP @ Flywheel: 588 @ 7500rpm
Max TQ @ Flywheel: 459 @ 5500rpm
Max RWHP: 470.4 @ 7500rpm
Max RWTQ: 367.2 @ 5500rpm
This is assuming a 20% drivetrain loss.
This is inputing the info like I have read to do off these boards...using Solid instead of Roller for the cam setting and using Seat-to-Seat instead of .050".
I realize this is going to take some mad tuning to get everything worked out though. Anyone have any other input on what should be done to this setup?
Thanks,
John
Old Nov 26, 2004 | 07:06 PM
ME Leigh's Avatar
Car: 82 Z28
Just get the cam ground on a 114 LSA and it will make the computer tons happier.
Old Nov 26, 2004 | 07:18 PM
White91GTA's Avatar
Engine: 5.7L TPI
OK...so other than the LSA being too low, you think everything else is fine? I really do appreciate your input on this, since you are the only one that has actually expressed any interest in helping me with this decision. Thanks again.
John
Old Nov 26, 2004 | 07:49 PM
ME Leigh's Avatar
Car: 82 Z28
I'm not sure, you might want to ask on the TPI board, they have much greater knowledge of the computers used in these cars.
Old Nov 27, 2004 | 11:33 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Looks like a good combo to me, but I don't know computer controlled cars (well, EFI in particular) too well.
Why do you want 1.6 rockers though? That cam has more than enough lift as it is, and thats with 1.5 rockers?
Old Nov 27, 2004 | 06:25 PM
White91GTA's Avatar
Engine: 5.7L TPI
Can never have enough lift...lol
I am looking to get the most power I can from the combo and the 1.6 rockers will give more lift and more power.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
