project resurection on all fours
Old Nov 24, 2004 | 04:21 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
well the tires are finally mounted and the wheels are on.
here is what it looks like today.
I still have to install the gas door and the spoiler and the windshield trim once i comes in from gm parts direct.
the list is long on what has been done to this. once starting as a car with ok paint bad interior and a blown trans.
new hok paint
eiback springs
koni red shocks and struts
spohn performance lca, lca reloc brackets, tourque arm, panhard bar, misc front end parts.
bear brakes
polished this and that
4th gen seats
new carpet
headliner
neons
stereo with sub box
new seals
new front nose gfx fenders and hood
9 bolt posi
boyd rims
bfg kdw tires
rebuilt trans with all the goodies
new leather wrapped steering wheel
newer t tops
misc engine parts
and i;m sure there is more..as i know i have some more stuff coming
145 mph speedo, new gm hood louvers the list goes on.
what ya think..who says a amature can't paint
jeffw
Old Nov 24, 2004 | 04:22 PM
JeffW's Avatar
Engine: 305 tpi LB9
heres the front
Old Nov 24, 2004 | 04:24 PM
LUVmy92's Avatar
Car: Camaro
Looks hot man!
Old Nov 24, 2004 | 04:25 PM
JeffW's Avatar
Engine: 305 tpi LB9
hope to get some dry weather so i can finish detailing it compound is in every crack of the car.......and i;ll take some pics in the sun if it comes out
gotta luv tgo you guys were a huge help in completing this project thus far.
jeff
Image removed- Three images per thread, as per the rules. Normally I keep the first three, but I'm sure you want that outside pic up. Please host more pics elsewhere to post them... and then post a lot of them
Old Nov 24, 2004 | 04:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That is BAAD!!!
Old Nov 24, 2004 | 04:40 PM
85_ZED28's Avatar
Car: '85 Z28
You car is awesome!! Can't wait to see full shots! theres just something about that colour :hail: :hail:
Old Nov 24, 2004 | 04:42 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
that look sweet man... what kinda of rims are those?
Old Nov 24, 2004 | 04:47 PM
JeffW's Avatar
Engine: 305 tpi LB9
boyd coddington smoothie II
17x8 with 245 45 17 frt
17 x 10 with 285 40 17 rear
Old Nov 24, 2004 | 05:08 PM
nolanr0413's Avatar
Car: Trans am
sweet . what bs did u get for the rims in the back .I got 5.5 .
edit: car looks great i almost forgot to say . You musy be so happy to be about done. But the car is away for the winter right?
Old Nov 24, 2004 | 05:11 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
dam that looks sweet man i love it cant wait to see some pics of her outside :rockon: :yourock:
Old Nov 24, 2004 | 05:16 PM
JeffW's Avatar
Engine: 305 tpi LB9
thanks nolan your car was the inspiration for me getting the rims.
5.75 on the rear 4.5 on the front guess is should of posted that too since someone may need it. i also had to find the right lugs. the ones that i had on the car needed a 13/16th socket. with these boyds you can only fit a 3/4 so i got mcguard tuff lugs and lock set.1.5 12 mm conical seat with closed end, what a pain to sort through all the types to find. they finished em off nice and they are great quality guaranteed not to rust either. with my 13" brakes the stem is so close to the caliper i can not run the chrome cap only a plastic one will work. the stem is very short now i may have to find one even smaller like the ones that bolt from the inside to be able to run a chrome cap. with the crome cap it just ticks the caliper. it would suck to snap that stem off while driving. all in all i am super pleased with the look.
the car also has a rake look to it, i wonder if its the relocation brackets that do that. i not sure what makes it sit like it does but i like it. off the stands makes it look completly diffrent.
its away for the winter sitting in the garage..took so long to finish but i am very pleased with the results all the hard work and sore everything was worth it. i will get it outside to run some just no driveing till spring when i will plate it.
Nikole's Avatar
Car: 1992 RS
lookin good
Old Nov 24, 2004 | 05:40 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
:hail: :hail: :hail:
man, i have watched this since you posted the first "project ressurection part 1" and WOW MAN, im sooo impressed, it turned out so nice dude. Your choice of color was awsome and man did you do a great job, hats off to you!
nick418's Avatar
Engine: L98, Hemi 6.2
damn jeff your car is amazin! i love the boyds!:hail:
Old Nov 24, 2004 | 06:00 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
very nice
Old Nov 24, 2004 | 06:30 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Kickin' *** on the wyiiiiiiiilde siiiiiiiiiiide!!!!!!
That color is goin' to be so clean in the sun!!!!
Especially once you get all the blackout work done...
Any plans for the Spohn frc's???
Old Nov 24, 2004 | 06:37 PM
JeffW's Avatar
Engine: 305 tpi LB9
thanks Kevin...you gave me some great advice and it show
yep sfc thats a mod i still need to do, but i need to find a shop i trust to weld em in, car is pretty solid i can hold it up on 3 stands, not that i try it but it tends to just happen when it is way upi high like for the trans work. i do have a strut tower brace in black to install now that it is on the ground i can do that.
jeff:
Old Nov 24, 2004 | 07:38 PM
megaracerx's Avatar
:werd:
awsome car man! i love the color :hail:
Old Nov 25, 2004 | 12:19 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
What a long way that car has come... Keep us posted. I can't wait to see it in the sun
Old Nov 25, 2004 | 12:46 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
well after seeing the results i am going to try to paint my car myself. your car is very inspiring!
ive watched it since the first post
excellant car jeff, keep up the good work
Old Nov 25, 2004 | 01:05 PM
CaysE's Avatar
sah-WEET!
Old Nov 25, 2004 | 01:18 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Very nice, I remember when you first started workin on it, now you just need some outdoors pics to show us the Candy paint!
Old Nov 25, 2004 | 01:51 PM
Spdfrk1990's Avatar
What tires are those looks real good. You bought a new nose was it a gm peice?
Old Nov 25, 2004 | 02:00 PM
JeffW's Avatar
Engine: 305 tpi LB9
yep new bumper cover was gm and lower gfx, 1 new gm fender and 1 after market fender and hood
tires are bfg kdw
Old Nov 25, 2004 | 02:01 PM
Spdfrk1990's Avatar
Did the aftermarket fender fit ok
Old Nov 25, 2004 | 04:40 PM
Car: 1987 Z28
this may sounds a little wierd but you should paint the inner fender walls....you know those plastic cover thingys? yea you should paint them black they look a little dirty/rustyish
Old Nov 25, 2004 | 04:51 PM
Spdfrk1990's Avatar
Wait its plastic it dont rust he can just buff it and spray some tire wet on it so dirt doesnt stick.
Old Nov 25, 2004 | 06:25 PM
JeffW's Avatar
Engine: 305 tpi LB9
yep the inner plastic needs a good scrubbing.. the after market fender is ok not gm perfect for sure there is a diffrence on the inside.. it did take some working it to align just right more bending than the gm fender.
can't wait for a sunny day to get it out and take better pics. did some detailing today after i found the problem with the intake gasket. parts run tomorrow...never ends gotta love it
Old Nov 26, 2004 | 05:49 PM
JeffW's Avatar
Engine: 305 tpi LB9
one nightime outside pic
now that it is running woo woo
Old Nov 26, 2004 | 05:50 PM
Spdfrk1990's Avatar
Wow i like that blue what color blue is that.
Old Nov 26, 2004 | 05:53 PM
JeffW's Avatar
Engine: 305 tpi LB9
house of kolor cobalt candy blue
can;t wait for the sun to come out for day time pics outside. that garage does not do it justice as neither does digital cameras.
Old Nov 26, 2004 | 05:55 PM
Car: 1987 Z28
HUBUDA HUBUDA HUBUDA!!!!!!
MAN THAT THING IS SWEET
again man GREAT JOB!:hail: :rockon:
Old Nov 26, 2004 | 05:57 PM
Spdfrk1990's Avatar
What are the parking lights i forget 1157's? If they make them in silverstars u need them the ones that are blue till u turn the flashers on then they are orange.
Old Nov 26, 2004 | 06:51 PM
JeffW's Avatar
Engine: 305 tpi LB9
i want some i need some silver stars huh i gotta go find some that will be cool
Old Nov 26, 2004 | 10:53 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
That looks sick man.
I love that color blue and those wheels look great. I can't wait to see some daytime pics. Very nice work.
Old Nov 27, 2004 | 12:59 PM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
i just know those pics dont do any justice... but it still looks great.
i'm excited to see better photos.
p.s. neons look great
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
