Engine swap from 96 Police Impala SS to my 91 Camaro
Old Dec 1, 2004 | 09:52 PM
91NiteRida''s Avatar
Car: 1991 Camaro
Well,
I have a few questions about this engine I came across...Its a 96 Impala SS police car that was stolen and then stripped...It has 9K miles on the engine...My dads friend said it was a TBI but im thinking it was TPI..Im wondering if this would be a good engine for my camaro...I would throw on my Edelbrock intake TBI and throw on a 350 TB.From what I understand it already has "hi performance" heads and cam...Hes asking 750 for the engine...What does everyone think??I have my stock trans but ill be replacing it soon with a t5 or t56...And ill have 3:42 gearing...Let me know what everyone thinks
Old Dec 1, 2004 | 10:17 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Its and LT1 standard SBC parts do not work. The LT1 is better then the older SBC, feel lucky.
Old Dec 1, 2004 | 10:43 PM
Car: 1991 Camaro
so i should pass up on it?
Old Dec 1, 2004 | 11:05 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
umm no. thats a pretty damn good engine stock. its the same thing the 93-96 i think camaro/firebirds have. get the motor and trans. i think painless sells a wiring harness for the motor. get that and then get ready for one hell of a swap. ive seen its not hard but very time consuming with all the wiring.
i kinda know this becuz i did a swap on my friends firebird. took a 88 gta andripped the motor, wiring harness, driveshaft, gas tank, fuel lines, radiator, and fans. and swaped it into his 86 firebird whic was a computer controlled carbed 305. the wiring was the worst part.
Old Dec 1, 2004 | 11:58 PM
ME Leigh's Avatar
Car: 82 Z28
Actually you might want to find out what size it is and what material (iron, al) the heads are made of. Some impalas and alot of police cars go the "baby LT1) the 4.3L V-8. Pass if its not a 350.
Do a on here to find out if you want to tackle the swap.
Old Dec 2, 2004 | 01:07 AM
Car: 1991 Camaro
thanks for all the info fellas....So its not as easy as i thought it would be to just swap my intake on the 350...
Old Dec 2, 2004 | 07:47 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
If it's a true SS I highly doubt it would be saddled with a 4.3 v8
Old Dec 2, 2004 | 12:07 PM
ljnowell's Avatar
I have never seen an SS police car. A lot of Baby LT1's in cop cars though.
Old Dec 2, 2004 | 12:19 PM
Drakar's Avatar
EDIT - yes 9C1 Caprices got the baby, LT1 was optional.
check the 8th digit of the VIN should be P
and check the casting number on the block.
Old Dec 2, 2004 | 10:46 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
my dads 94 caprice has the "baby lt1" its a 256 ci. my friend that has a 95 or 96 caprice got his with the real LT1 in it. so just get the castin numbers nad run them on the web and find out what u get.
Old Dec 4, 2004 | 07:11 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
All Impala SS's have an Lt1. All 9C1's however do not have an Lt1. Check the VIN like mentioned above, the rear of the block(drivers side I think) to make sure. The RPO code sheet should be on the trunk lid. If it is a true Lt1, then it will have iron heads that are NOT a bad thing. They OUTFLOW the heads from the f-bodies and Corvettes. Their only downfall is that they are heavier.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
