Small Block 454 Dyno Pull Videos!
Old Dec 2, 2004 | 07:31 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
I finally got my camera home and made a few pulls..
This is a full pull, made 508hp @5500 and 557 ft lbs @ 4400, ran out of fuel at 5700 you can hear the little miss.
www.tpijeep.com/video/454dyno.WMV 5 mb
Second Video is some low speed torque pulls, top readout is RPM and bottom is uncorrected torque, the numbers you see there are 5-6% low when you add the weather correction in.
www.tpijeep.com/video/454dyno2.WMV 7.5 mb
Old Dec 3, 2004 | 06:02 PM
Dr G's Avatar
Thanks for taking the time to post them TPIJeep! Much appreciated. The problem is it makes me want a similar set-up for myself!!!
Very impressive!
Will you get some videos once the engine is in the jeep? Perhaps of you scaring the locals at the traffic lights?
Old Dec 3, 2004 | 09:50 PM
TPIJeep's Avatar
Very impressive!
Hopefully I can get one of it pulling a wheelie!
Old Dec 3, 2004 | 11:42 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
I would be interested in wheelie videos!!!!
What cam /heads/intake do you have on that 454? It looks and sounds pretty mean in the videos.
Old Dec 4, 2004 | 08:52 AM
TPIJeep's Avatar
The specs are listed in this thread.. there is another thread with my name on it with some build up pics as I was assembling it.
https://www.thirdgen.org/techbb2/sho...hreadid=268934
Old Dec 4, 2004 | 11:20 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
What made you decide to go all the way to 454ci? That is the max bore for the block right?
Did you ever think of going with a slightly smaller bore so you could rebuild a few times? Or are you planning on sleeving it when its time for a rebuild?
Its awesome, but those were my first thoughts...
Edit: What are the specs on your camshaft?? I didnt see it in the other thread
Old Dec 4, 2004 | 12:17 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Question: How do you get a SBC to 454 cubic inches? Is that an aftermarket block?
Old Dec 4, 2004 | 12:29 PM
TPIJeep's Avatar
The chances of me ever wearing out the block are slim, I just don't run it that much but we have some kick butt sleeves I can put in if there ever was a problem.
If I would have known they had a 4.25 crank out I would have gone that route and kept the bore at 4.25 but it took so long to get the crank I didn't want to wait any longer.
The cam is a 280ish duration and 630 lift.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
