Timing Explained
Car: An Ol Buick
Engine: Vsick
Timing Explained
In here are some *tips* about tuning, and timing. If this article, isn't second nature to you, I'd suggest you reread it until it is.
And if you think you know it all, then try rereading it with a more open mind.
Yes, it's that good, IMO.
HTTP://WWW.Streetrodstuff.com/Articl...tion/index.php
And Doc agrees with me.
Car: 91 Red Sled
Printed the whole thing out. Will read it in greater detail later. From what I've scimmed through he has a lot of info being given away for nothing.
I already knew the difference between the 2 but I learned how to tell the difference between them. Not that the audible knock in a 14.5:1 compression engine isn't hard to hear... it's just well, so loud without a muffler
I also like how he went into the design aspects like compression , quench, and probably most overlooked, the spark plugs. Just reading it makes me wonder about or little FSAE engine. We're a restricted car but anything below 10000rpm we're making more horsepower! We've polished the sharp edges out of the combustion chamber but have been using NGK Iridium tipped spark plugs that were ment for the stock engine compression and chamber design. The Iridium is suposed to have a wider temperature range than standard copper plugs but I bet it's worth looking into because we had a couple cases of pre-ignition on our open loop tunes.
Bruce, what do you recommend to the rest of use that aren't exactly elite plug readers? I'd like to learn while my eyesight is still good.
.I also like how he went into the design aspects like compression , quench, and probably most overlooked, the spark plugs. Just reading it makes me wonder about or little FSAE engine. We're a restricted car but anything below 10000rpm we're making more horsepower! We've polished the sharp edges out of the combustion chamber but have been using NGK Iridium tipped spark plugs that were ment for the stock engine compression and chamber design. The Iridium is suposed to have a wider temperature range than standard copper plugs but I bet it's worth looking into because we had a couple cases of pre-ignition on our open loop tunes.
Car: check
Engine: check
Transmission: check
What I've always done for plug selection is to run the coldest plug possible that doesn't foul. Had many a folk at the auto supply store ask "what are you putting these in?". "You want what(!) plug?"
RBob.
RBob.
Car: An Ol Buick
Engine: Vsick
While the new fuels burn with a lower level of ash, the rings still develope.
The biggie, is now with EFI you have DFCO, so you don't have to play the insane games of doing plug cuts, like in the old days. Well let me qualify that for anything on the street, that's got a decent ecm.
Get a magnifier.
Practice, and when your done practicing, do it some more.
Play the indexing game, see what happens. Try using 1-2 plugs of different heat ranges (at the same time), and see back to back what they look like.
You don't have to run at 6,000 rpm to get valid plug information. Again, the newer fuels burn with less ash, so you might need to drive 100 miles at cruise to stain the plugs.
And reread the section on how fast **pre-ignition** can totally destroy an engine. Kinda shreds some light on these claims that *detonation* won't instantly melt down a motor.
Did I mention practice.
Car: An Ol Buick
Engine: Vsick
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
RBob.
RBob.
I get that at auto parts stores all the time. "Why do you want 8 plugs for a GMC Safari? They didn't put a V8 in those."
nope, THEY sure didn't...
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
GREAT article. Straightens out some things I wasn't clear on (the differences between the two, mainly.) I think I'll print it out and read it a few times at work tomorrow.
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
Great article. Learned a lot, and will learn more later when I read it again.
I'm surprised you've had such good luck w/ Champions. Everything I ever put them in ran like a lawn mower. I prefer A/C's. Just my opinion from bad experiences.
Mike
Mike
Car: 85 Berlinetta F41
Transmission: TH700
Axle/Gears: 3.73 posi
Very informative but I found some funnies hahaha
piston with a very nice bum pattern right in the combustion chamber
some 160-180 degrees of bum being compressed
Start out rich, retarded and with cold plugs
Rich and retarded... all I need is money and im there!
not saying I can type well just that the typo's or wording were funny to me.. :lala:
really gave me an idea of what im looking at now when I take my spark plugs out... seen a few chipped... not good
Car: An Ol Buick
Engine: Vsick
Originally posted by V8Astro Captain
I've had great results from the Champion Truck plugs.
Champions are of rather soft material. This softness, leads to an easy decay of surface, so that an ion path can form, which is what allows the spark to jump the gap. A spark doesn't happen instantly, if you've seen pictures of lightning strikes with the *trailers*, being emitted in front of the actual strike, the same thing goes on in a combustion chamber. What makes a truck plug is that the center electrode is fatter, and has more material that cam be eroded off, before the gap starts to noticeably increase. In a car with a marginal ignition system this ability to erode more easily, and form the trailer, is an advantage.
180d opposed to this is the Autolites. They are a much harder material, and dont erode as easily. A/C are just slightly softer then the Autos.
Running 10-15,000 miles with a set of each will demonstrate the different erosion rates.
I've never had NGKs perform well in anything other then rotories, or motorcycle engines. I think it's an inherent characteristic of the design, and way they design them to establish the heat range. While you can select them, and be happy with one heat range, on any given day, they might read too hot or cold.
Sr Jacobs, in his *The Drs Guide to Optimising you Ignition System*, also agrees with most of this.
Again, plug reading is part art form, so opinions are gonna very.
I wonder where the article came from originally. Member
Transmission: TH700
Sorry to go off topic slightly, what are your opinions on the Accel short header spark plugs... thats what ive been running in my 307 because they keep the wire a good distance from the headers.. every time I check them they get completely black and some chip some porcelean.. this is a chevy 307 with a 600 holley VS I know it may need smaller jets but are the plugs bad quality also?
Car: An Ol Buick
Engine: Vsick
If they're sooty, then leaner or hotter plug.
Fragmenting the porclean, is a no-no. A big time no-no, did I mention fragmenting a plug is a big no-no?.
If you have a close plug, I'd say pull the header off, and fix it. While dimping looks bad, to you the engine don't care unless you pinch off like 1/3 of the cross sectional area. Right up by the port the gases are so hot, and **thin**, so they *bend* very easily.
And during the *scavenge* part of the cycle it's the slug of gases moving way down stream that form a low pressure area along that column that helps, again 1" in a tube 3' long isn't going to matter much if at all. Toss in a muffler and headers really don't work as well as often predicted.
Just what I've seen, I'm sure others will have seen the opposite.
Transmission: TH700
I dont think the wires would get melted but they were 10x easier to change with the extra clearance and I didnt want to chance burning up my $30 wires.. denting in the headers doesnt sound like something I want to do.... I can fit different plugs without altering my headers.. so ill try, but what plug would be better than my accels?
Car: An Ol Buick
Engine: Vsick
Car: check
Engine: check
Transmission: check
Originally posted by AlexJH
Their OCR software needs some work, LOL.
I wonder where the article came from originally. by Allen W. Cline
This article was originally published in the January-February 2000
(Volume 10 Number 1) edition of *Contact!* magazine. This magazine is
published bi-monthly by the Aeronautics Education Enterprises (AEE), an
Arizona nonprofit organization."
Allen was the lead designer of the NorthStar engine.
RBob.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Thanks for the link....I Just might pull a plug or two while the wife is christmas shopping Friday.
With these fast burn heads, not needing as much timing at wot. As a general rule. What is the MTB for this type of head? Allen mentioned 20* in the article.
Engine: all 225+ RWHP
Transmission: all OD
Wow!
That was good reading there!
Words to live by :-) Im just glad on all the wonderful things that have happened to me and my cars(water/valve springs/oiling issues) the one that I have managed to elude thus far is pulling the plugs and finding them melted, metal flaked, or eating themselves alive. *Im knocking on wood*
Thats great article
later
JEremy
Thats great article
later
JEremy
Car: 88' IROCZ
Axle/Gears: 2.77
RBob.
RBob.
After some setbacks (not engine) I got it running and I'd like to ask some questions for anyone to answer.
- What should my base timing be? (currently 8°)
- What should my total Timing be? (89' ARAP is set 41°)
- What spark plug heat range do I need?
- Do I need a different Knock Sensor? (current L98)
- Why is my idle low when cold, and high when warm? Doesn't that seem reversed? I read at Corvetteforum's Scan & Tune to set the stall saver spark enable thresholds to zero to solve the problem, does anyone have any comments on this? I like to have some input before I do this. I've increased the Desired Idle RPM vs Coolant Temp 200rpm across the board didn't seem to help at cold idle.
- Are there any suggestion/recommendations before I go for the smog test?
Car: An Ol Buick
Engine: Vsick
Originally posted by rgarcia63
[*]What should my base timing be? (currently 8°)[*]What should my total Timing be? (89' ARAP is set 41°)[*]What spark plug heat range do I need?[*]Do I need a different Knock Sensor? (current L98)[*]Why is my idle low when cold, and high when warm? Doesn't that seem reversed? I read at Corvetteforum's Scan & Tune to set the stall saver spark enable thresholds to zero to solve the problem, does anyone have any comments on this? I like to have some input before I do this. I've increased the Desired Idle RPM vs Coolant Temp 200rpm across the board didn't seem to help at cold idle.[*]Are there any suggestion/recommendations before I go for the smog test?[/list]
Lean cruise means lots of timing, good mileage, but puts more heat into the oil. I'd rather run 36, and have a longer lasting engine.
Heat range is a matter of how you tune. Pick one, and start reading them to see if you got what you want.
You want a K/S that is most closely matches your cylinder bore, and is of the right resistance.
Too lean during cold run will make for a low rpm. Sometimes setting the commanded rpm higher in fact makes matters worse. Gotta experiment some.
Grumpy,
That 36 Total timing you use, when working with a 730 is that the field SPARK ADVANCE MAX.
If so I currently have it set at stock with 42deg.
How is that 42 calculated? I am pretty sure this has been covered heaps of times. But is that 42 calculated without the base timing added or with it.
Or does that 42 mean that if you add higher values then 42 in the spark advance tables they will not affect it as the ECM will only give a max of 42? So if you had 44deg in some spots in the spark advance tables the ECM would only give you what ever the max constant is set to in this case 42?
Car: An Ol Buick
Engine: Vsick
Originally posted by IroczInOz
Grumpy,
Grumpy,
Car: 91 Camaro RS
Axle/Gears: 2.73 Posi w/Disc
Now I get it! For the life of me I couldn't figure out what "180* of bum" was...hehehe...
I like very nice bum pattern.
Oh -- I just saw another one: "Start out rich, retarded and with cold plugs...". I know those people!
But really, everyone should read that article in the first post (Everyone who's not already read it -- this is an old post.).
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
Re: Timing Explained
Great read!!
One thing that really caught my eye was when he said "if you do a full throttle 0-60 blast, the engine will likely run up to 6000 rpm at 11.5:1 or 12:1 afr. But under sustained load, at about 20 seconds, that afr is richened u by the PCM/ECM to about 10:1. That is done to keep the spark plugs cool, as well as the pistoncrowns cool."
This caught my eye because it makes me wonder if we have the ability to change this "richer" value, based on certain conditions such as wot duration and increased load for an increased duration?
Another reason this caught my eye is because I never factored in preignition due to a longer duration under wot or a longer duration of higher engine loads, and I don't think alot of people factor that in. Most probably get their target afr all the way to redline, and figure that it's good and don't think twice about buildup heat on the plugs. But, I was planning on tuning in open loop and leaving in open loop basically because I trust my wideband over blm's that the computer uses, which are provided via inaccurate narrowband. But after reading that I would like others opinions on this. Is there a function in our ecms to provide more fuel over over extended duration, based on a kpa value? I am using tuner pro and don't remember seeing one for closed loop or open loop, or is this what the pe function takes care of?
Car: check
Engine: check
Transmission: check
Great read!!
As for stock GM mask's that we use, I don't know of any that have this functionality.
RBob.
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
I guess I should tune conservative and not beat on it all the time. Do you reccomend a colder plug, and if so how many steps colder?
Car: check
Engine: check
Transmission: check
For plug recommendation, third post of current thread: "What I've always done for plug selection is to run the coldest plug possible that doesn't foul."
For a street tune keep it conservative. Stay on the rich side along with WOT SA timing being correct.
RBob.
RBob.
Dig
Car: check
Engine: check
Transmission: check
$58/59 has an extension to the PE system. If MAP is at 100KPA or more for a period of time, then PE AFR gets reduced by a KPEAFDLT amount.
Makes sense now, when you take it in the context of this article.
I don't play with the Buick stuff (T31)much, but wasn't there an AFR vs. Time table?
Dig
Dig
Car: check
Engine: check
Transmission: check
I see it now. On the $58 code there is also a MPH qualifier. So, once over a MAP and MPH value for a period of time there is a single step wise reduction in AFR. Funny thing on the AMUW GrandAm calibration it isn't even used.
RBob.
RBob.
Street Lethal
Apr 30, 2019 12:14 PM
