heres correct order for 454 IAC wireing
Old Dec 17, 2004 | 10:48 PM
Reds ttype's Avatar
Car: Turbo Buick
Engine: whistling V6
Transmission: lots of broken ones
on the flat 4 IAC connector for a 454 tb it goes as follows
A green / black stripe
B green / white stripe
C blue / black stripe
D blue / white stripe
I post this because I searched on here for it and I kept seeing the opposite of what I posted so even tho the plug I cut off a junk truck had the color code I posted I wired it up backwards like I read on here and it wouldnt Idle for crap
I switched them around to the order above which is the original order on the plug I have and It works perfect
hope this helps some that are fighting Idle problems with 454 tb's
Old Dec 18, 2004 | 01:27 AM
25THRSS's Avatar
I believe turbo city makes a simple plug and play adapter.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
