Belt question?
Old Dec 27, 2004 | 11:45 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Belt question?
My AC clutch is starting to sieze up and is knocking like crazy when the car is cold. Is there a way to bypass it. Now i was told you could run the non ac belt and just skip the compressor. However, is this possible, because if it was why would they make ac delete pulleys? Very confused, maybe someone here knows more Thanks
Old Dec 28, 2004 | 11:52 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Where can I buy an A/C delete pulley for our v-6? Thanks
Old Dec 29, 2004 | 12:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If ya do a <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a>, vsixtoy and a few other guys had a message going recently about this, I think.
Old Dec 29, 2004 | 12:14 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah i been doing alot of seaches on it, learned alot, but not exactly what i am looking for
Old Dec 30, 2004 | 12:06 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Sorry, I just read this for the first time. I have a Factory Camaro A/C delte pulley on my truck. I'll go get the part # off it and take a picture of it. It will work on either a V8 Camaro or a V6, they are the same A/C compressors.
Old Dec 30, 2004 | 12:20 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
GM has this labeled as a waterpump pulley- it is not such. It cam on factory IROC's that had no factory air.
It is GM part # 10055890
Imput that part # on this site
http://www.gmpartsdirect.com/results.cfm
Here's a shot of it on my work truck ('89 350TBI)
Old Dec 30, 2004 | 01:12 AM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah but, isn't the way it mounts different then the v-6?
Old Dec 30, 2004 | 01:29 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Yes, but it works identical. It just on the opposite side of the motor and it mounts right side up (not upside down like on my truck)
Old Dec 30, 2004 | 10:28 PM
Engine: 2.8 Lt
Transmission: 5 Spd
So I should be all set if i go with the V-8 AC delete pulley? And it doesn't matter how it is mounted? Thanks again man
Old Dec 30, 2004 | 10:30 PM
Engine: 2.8 Lt
Transmission: 5 Spd
And will the orginal belt still fit is the question?
Old Dec 31, 2004 | 07:21 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
It should, the pully is the same size or should be at least as the a/c pully. I had heard a rumor that you could use that delete pully in place of the smog pump as well, that true? My smog pump is currently hollowed out but I want it off the car and I can't just get a shorter belt as it will rub.
Supposedly you can just get a shorter belt and bypass the a/c but it didn't work on my 3.1, th ebelt rubbed on the top of the water pump pully.
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
