Innercooler for Vortech Super Charger
Old Feb 22, 2005 | 12:03 PM
kingbabone's Avatar
Who makes a good - priced reasonable inter cooler that can be fabbed into a 3rd gen with a vortech supercharger.
Mike
Old Feb 22, 2005 | 07:29 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Innercooler for Vortech Super Charger
Mike
We've got a couple threads on this, that someone really needs to make into a sticky..
We all found one on ebay that works really well.
basicly you rotate the volute housing (will need to notch the bracket a little bit), aim it twords the driver fender. Then go 90 down and forward, and 90 into the intercooler that sits behind your radiator.
Then on the other side, come 90 out of the intercooler, 90 twords the driver til it just rubs the radiator, then 90d into the throttle body.
I'm putting my motor in next week, and will start putting pictures up of my setup, but mine isn't TPI. so the second half of the plumbing will be different.
-- Joe
Old Mar 1, 2005 | 08:35 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I put my motor and tranny in.
I gotta put the DS up, shifter, and a few other things underneath then I'll lower the car and start up top. I wanna break the motor + cam in this week, and start on the intercooler plumbing.
I'll be putting pictures up of my progress.
-- Joe
Old Mar 5, 2005 | 01:06 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The intercooler to use, from ebay:
Old Mar 5, 2005 | 01:12 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You will then need to rotate the blower volute. It will hit the bracket, so you'll need to grind the bracket in two spots.
The bottom part, and the side:
Old Mar 5, 2005 | 01:16 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally I tried mounting the intercooler with 2 bolts as shown in the picture. This didn't work out too good.
What I ended up doing was cutting the tops of the radiator support and pushing that forward to give more room for the IC.
Also cut both sides flush with the frame rail, so the intercooler inlet and outlet are not obstructed.
A few strips of 3m weatherstripping on each side of the intercooler and it should fall right in place.
You'll know when the supports are pushed enough forward, that the radiator falls back into its original position.
Attached Thumbnails Innercooler for Vortech Super Charger-intercooler-mod.jpg
Old Mar 5, 2005 | 01:36 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The intercooler should look kinda like this. Then you can bolt the radiator back into place:
Old Mar 5, 2005 | 04:07 PM
83 Crossfire TA's Avatar
You know, If enough of you are interested, I can get those pretty cheap… If I could get 5 or more orders together I could pretty much lock down a price toward the bottom end of what they go for on ebay. It might be nice to have someplace that you can just go and get one, instead of hoping to snag one on ebay at a decent price.
I’ve got one for my own car already, I wanted to get one in and see it in person and the thing really is pretty nice.
Old Mar 6, 2005 | 07:24 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i got the same one from Ebay. im gointo be using it in my little turbo project on my 305 until my bbc is done. im glad to see someoen else got this and is using it. cant wait to get my turbo kit and get things done.
Attached Thumbnails Innercooler for Vortech Super Charger-c-tims-pics-dont
Old Mar 8, 2005 | 12:15 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
how big are those intercoolers
Old Mar 8, 2005 | 12:32 PM
nightrider87's Avatar
I'd be up for it probably.
i've got an intercooler already but depending on what you coudl get those for...
Old Mar 8, 2005 | 03:03 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
normally these go for $170 dependin on the ebay acution. i got mine for $210 shipped to door.
the intercooler measures 24w X 12h X 3 1/4 thick.
Old Mar 21, 2005 | 05:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Joe,
Deff post more pic's when you get em.
here are some of my FMIC same one from ebay
http://www.cecoatings.com/images/Car...rboMotor/FMIC/
This is how I plan to fab up a bracket and mount mine.
Old Mar 21, 2005 | 05:51 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by TPl383
Joe,
Hey Man,
Cool beans!. I didnt wanna run the plumbing under the car, so I chose to run it up top. I'm in the process of changing the silicone couplers.
I decided to use a 90d silicone coupler off the blower, to get a tigher radius.
Old Jun 6, 2005 | 09:43 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Finished product
Old Jun 6, 2005 | 10:02 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
For folks with TPI, add another silicoln 90d bend (3" to 3"), a 3" straight section of pipe, a silicoln coupler, and an LT1 aluminum throttlebody elbow.
I'm not an artist, but you'll get the drift from the pic:
no green
Jan 9, 2016 09:22 PM
anesthes
Sep 30, 2015 07:48 AM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
