t56 stats
Old Mar 3, 2005 | 02:49 AM
davcamaro's Avatar
Car: 1985 IROC
t56 stats?
does anyone have the statistics on the t56? I am curious what the gears are (it has a better 1st gear than the 700r4 right?) and how much hp/tq it can handle. I heard also that it had two overdrives is this true, if so what is the point in that?
Old Mar 3, 2005 | 01:05 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Ratios and such:
trans............1st....2nd.....3rd.....4th....5th.....6th.....R.....TQ rating
'93 M28........3.36...2.07...1.35...1.00...0.80...0.62...3.28.....350ftlb
'93 M29........2.97...2.07...1.43...1.00...0.80...0.62...3.28.....400ftlb
'94-'97 MN6...2.66...1.78...1.30...1.00...0.74...0.50...3.28.....450ftlb
700-R4.........3.06...1.63...1.00...0.70......................???......????
The "double overdrive" means 6th gear is an extremely high gearing. This means low highway RPMs even with a very deep rearend. I run 3.70s in the back and turn about 1800 at 80mph on the MN6 tranny. This in turn is a big gas mileage boost if you spend any time on the highway.
Old Mar 4, 2005 | 03:37 PM
davcamaro's Avatar
Car: 1985 IROC
ratios
so, I guess mn6 is the other name for the t56? either way, is it possible to change the first and/or second gear(s) to make them lower for better accel? I know it would make some difference, but I amnot totally sure it is really worth it, or if the difference is significant. I am used to the lower first of the 700r4. The lower gear means a better start off the line right?
Old Mar 4, 2005 | 07:59 PM
colonboy14's Avatar
Car: Trans Am
With something like 3.73's, first gear goes by really fast, and sixth is perfect on the highway. I wouldn't want to lower first any more than it already is. You'd be shifting before you got the clutch out all the way.
Old Mar 5, 2005 | 03:36 AM
davcamaro's Avatar
Car: 1985 IROC
3.73 gears
I am looking at getting 3.42 gears (someone told me it is actually 3.43 but I still haven't been cleared up on the subject) in the rear, but I am still debating about going to 3.73. is the gear still pretty low for 3.42? Also, is it a good idea to go with 3.73 rear gears over 3.42, or maybe something higher; I may be doing a lot of highway driving though.
Old Mar 5, 2005 | 08:57 PM
TheGreatJ's Avatar
The M28, M29, and MN6 are all T56 trannys. They're just named differently because of the different gear ratios (like the M20, M21, and M22 are all Muncie 4-speeds.)
With the MN6 tranny, you can run a 4.10 rear and still be fine on the highway. I turn about 1800 at 80MPH with 3.70s. 3.42 was stock for the 4th gen T56 cars, and IMHO it's not enough gear for the tranny. I highly recommend the 3.7x range.
Old Mar 6, 2005 | 11:43 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Unless you have a set of 3.42s lying around, I'd stick with 3:73s. That is if you can stand a small amount of gear wine. If you see plenty of track use and wouldn't mind the extra gear wine, 4:10s would be perfect.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
