Installed vacuum reservoir
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I installed a vacuum reservoir today because my cam is so big that I have almost no vacuum to run the power brakes. I mounted it behind the headlights on the drivers side. Didn't know if anyone would be interested in seeing it. Its a little hard to see because of the sunlight. I have it mounted to a home made bracket that is 10 3/4" tall and 6 1/2" wide. I bent the top and bottom to make 1/2" lips to drill holes for mounting and painted it black. Works good. Gives me a little more vacuum than before. Only time it won't work well is if I press the brakes and then press them again too soon and don't give the canister enough time to refill. Otherwise, I like it.
Originally posted by 90firebird
wow, its an actual magical orb of power!
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
I instaled the same one you have, i dont know if i noticed a difference, maybe i have the lines crossed up, how do you have them set up, there is one valve and one elbow, if ya can tell me how much difference you feel so i can compare it to that.
Car: 87 IROC Z28
cool, thats the way i have it, didnt notice much improvement tho, did, but not as much, but then again i only drove it for 2 weeks after it, its been sittin since i painted it.
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
That's where my resevoir is mounted as well. I only saw a little improvement with mine. I think I'm going to have to spend the money and get a vaccum pump.
Then I can get an even bigger cam...
86IROC112
Aug 17, 2015 02:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
