Victory!!!! Victory!!!!!
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
I PASSED SMOG FOR THE ONGOING SAGA SINCE MAY when i was doubble the gross polluter limits , not to mention i passed with flying colors below average numbers, ill scan her later... and the best part is i didnt have to replace the cats, only the egr valve, egr vaccum modulator, o2 sensor, plugs wires, and lots of other stuf... oh well.. its all over never again will i have to smog thanks to sonora county.
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Congrats Eric, so is your car not running rich any more? My car is next, I should be in there in a couple of weeks or so.
Engine: 5.7tpi 350,
well its rich/lean couldnt tell you, it looks like my fuel pump is dieing i got code 13, and when running another scan it seemed biased lean so i think im just gonna leave it alone until i get my new sending unit/fuel pump cause i need to drop the tank anyway so i dont really care, gonna send the tranny off for warranty work too..
Car: 07 Silverado
Glad to hear the tranny will get fixed. Ya, I need to drop my tank also. I am picking up my new fuel tank this weekend. Also will be getting a new fuel pump and sending unit soon, within another week or so. Hope to have it all in by early or mid next month. I am going to replace everything I can get my hands on when the tank is dropped since it's a pain to drop it. Good luck Eric, hope everything works out. Should be seeing you guys soon for my smog.
Engine: 5.7tpi 350,
i dunno how im gonna come up with all this money before than, i need alot of work on this car i wouldnt mind a 1K loan.... ive been tryin to get a credit card just not working being young sucks sometimes, they say i dont have any credit so its a no well **** them how can i get credit if they dont give me credit.... oh well... im screwed take me forever to build up my car and fix what needs to be done...
and will ill be sure to give you a good rate for smog check.
Car: 07 Silverado
Shocks and Springs I will be holding off on. Mainly just trying to tackle the fuel system. Thanks for hooking me up with the smog.
I know what you mean about not having enough money, don't worry though. It will all work out in time.
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Victory!!!! Victory!!!!!
Congrats man! My smog check came in 5 mos ago and I decided not to test her. I knew she wasn't going to pass because of the way she was running.
I labeled her as a non runing vehicle. So, the only way to fix this problem is as follows:
New GM 383/ported heads/superram
T56 tranny.
I think once I am done, I will pass smog ;-)
Tommy
T56 tranny.
Tommy
Engine: 5.7tpi 350,
T56 tranny.
Tommy
T56 tranny.
Tommy
not necessarily, a motor change has nothing to do with how smog will turn out if your emissions equipment is not working properly, belive me ive seen some piles pass with flying colors, as long as your are in fuel control you can get your car to pass smog...
I work at a smog shop so i see this stuff all day long, what did/are you going to fail. and you might try getting a pretest done.
Car: 87 IROC
Engine: L98 5.7L TPI
Axle/Gears: 3:23
so you live in sonora county or just have your car registered there
i need a sonora address so i can register my 76 k5 damn arnold it was gonna be exempt the first of 2005 but the govanator changed the law in oct 2004 to leave it at 75 and under for now
hit me up bro
hit me up bro
Engine: 5.7tpi 350,
hit me up bro
hit me up bro
Engine: 5.7
you have to live there....like i do... part time it doenst work like that
Please tell me more about where I could live in CA and not be required to smog-check.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
the only exempt places are the middle-of-no where places. thats why they dont require smogging every 2 years, cuz the population is like 10.
Car: 87 IROC
Axle/Gears: 3:23
you know just as well as i do there are ways around that
Yes, the hardest part will be the computer programming so that it does pass smog. I hope I can find a great shop to tune her.
Tommy
Engine: 5.7
I always thought smog control in CA was absolute if the car was newer than ummm, 1976? -- that even if someone lived in the middle of Death Valley, their car had to be smog-checked every year or two.
Engine: 5.7
Here's the info and site:
http://smogcheck.ca.gov/stdPage.asp?...gram_Areas.htm
Areas of the State
All areas of California require Smog Check inspections when a vehicle changes ownership or is registered for the first time in California. Most areas also require testing every two years, at the time of registration renewal. The Smog Check program divides the state into four areas, with different requirements for each:
Enhanced Areas: These areas do not meet federal or state air quality standards for ozone and are California's smoggiest urbanized areas. Biennial Smog Checks are required here. Thirty six percent (36%) of the vehicles in these areas must have their biennial Smog Checks performed at Test-Only stations.
Partially Enhanced Areas: These areas were opted into the enhanced program by the local air pollution control district/air quality management district. Although similar to the Enhanced areas, no vehicles in a Partially Enhanced area are directed to have their biennial Smog Checks performed at Test-Only stations.
Basic areas: Vehicles in these less-smoggy or less populated areas must have biennial testing at licensed test-and-repair stations.
Change of Ownership areas: These more rural areas of the state require emissions testing only when a vehicle changes ownership or is registered for the first time in California.
Car: '02 Z06
Engine: L33 5.7
The level of smog-testing depends on the severity of pollution in an area, not the population density.
Engine: 5.7tpi 350,
Originally posted by OUTATIME GTA
bummer will, where you goin'?
what's so bad about cali?
the demanding, ivading, stupid laws, the stupid pigs, the taxes, oh the people, and the immigration.
sacramento is one of the highest in the nation for raising home prices= cost of living, also #1 for final or first destination for immigration only thing this means is alot of people who dont speak english and htis just really irritates me i welcome them to the country but please speak my language. i eventually want to move out of ca
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
How about naming places that are "better" and why?
No point in just stating negatives if you don't have a solution.
Stupid pigs/laws/people will be everywhere you go.
I for one enjoy the weather and being near an ocean.
Everything I need is here.
And when I say here, I mean Sac, screw So-cal.
Since you're leaving Will, can we have one more little meet to say good bye? Though I can't speak as an adult, I think sacramento is okay, like del said, it's got almost everything you need, more expensive though. Has its ups and downs, right?
Engine: 5.7tpi 350,
Car: 07 Silverado
I am moving to Northern Idaho, Coeur D Alene is the city, it's east of Spokane Washington. My father just sold his business and house in CA and moved up there. He bought me and my girlfriend a new house for one thing. Also, no smog for the cars, everything is cheaper up there, taxes, insurance, gas, etc. The average price of a home is $135,000. There is about 70,000 people in the imediate area, very spread out though, I love the country and rural areas. Jobs and pay are very similar to here, real estate is going crazy up there and that's what I want to get into, plus my dad knows people and that's how I am getting the hook up. Oh, the weather is cold and some snow during the winter, 90's during the summer. I will have to park my car during the winter which is fine with me because that's what I want to do with that car some day anyway. I will be getting a nice truck for the winter, 4x4, my girlfriends front wheel drive will be fine for her, not that much snow, plus they do salt and sand and plow the roads. Anyway, shall I go on, I think not. I am going to be getting rid of CFI and getting a Edlebrock Multi-Point system, etc, can't wait. We should for sure have a meet before I leave, I will let you guys know some exact dates by next week for sure, it will be no later than April 30 I know that.
Car: 07 Silverado
I corrected my last post, you are right of course, it's east of Spokane Washington, sorry about that. I am going to miss all of you guys too. I think I am the only TGO member in Northern Idaho, oh well, I will come visit, don't worry, at least I will still be on the boards. No worries about the salt hurting my car, she will never see the rain or snow when I am up there, strictly summer car only.
Engine: 5.7tpi 350,
man thats awesome deal i thought you were kidding, that is a really nice father to buy his son a house...must have had alot of money left over from his sacramento sale, hehe...anyway good luck to you and you will be missed and most definitly we will throw you a going away party.... i wish you luck
Car: '89 GTA
Well of course ya can't pass up a situation like that.
No reason for you to stay here if your pops' is gone and taking advantage of the lower cost of living there.
Your brothers and girl don't mind uprooting to potatoville?
Defiinitely must gtg this month.
Car: 07 Silverado
Actually not all of us are going to Idaho. My younger brother who is 8, and my sister and her husband are the only other people going up there besides me and my girl. I will still have an older brother and his girl and another sister who are staying here in CA. My girl is actually very excited about moving. For one she wants to get away from her drama filled family, and she can't wait to have her own house.
Hawk312
Aug 22, 2017 08:55 PM
steveiguess
Theoretical and Street Racing
Feb 19, 2005 10:45 PM
leirch
Feb 5, 2001 03:17 PM
