RPO code 74U, exterior color Victory Red
Old Feb 3, 2001 | 02:29 PM
leirch's Avatar
Guys,
My 87IROC came with the factory Victory red, see my link in the signature. Since then it has been repainted. I'm almost 100% sure that its the same color but i'm not quite sure. Could somebody with the same paint on there car give me that paint code from inside of the spare tire compartment?
I would know myself if i had the orignal interior in the car.
Thanks,
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 3, 2001 | 03:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
74U/9528 is 88-90 Red
74/9260 is 85-90 Victory Red
My Firebird
Part Diagrams
Old Feb 5, 2001 | 03:17 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Where do you guys get this information? My 87 IROC is coded 74U and factory labeled as Dark Red Metallic. Did they actually have a victory red or was it called Bright Red for the Camaro? There is a difference between red and dark red!
Check out the window sticker - http://www.users.qwest.net/~smoyer/i...dowsticker.jpg
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
[This message has been edited by scottmoyer (edited February 05, 2001).]
hectre13
Dec 11, 2023 08:14 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
